Speaker : which one is better for rear ...
Speaker : which one is better for the rear speakers, Infinity kappa: 63.9I , 62.9I or 62.7i?????????? Three way speakers or Two way speakers????? ansd also for front speakers??????????????
I started out with the 63.7s in the front. Eventually I taped over the tweeter because it was too much for me at high volumes even with the treble turned all the way down.
Now I have only the 6.5" running, the other two are unplugged so I would've been better off with only the one-ways. I don't like metallic tweeters but some do. I installed the 1021 tweeters (textile dome) in the dash and they sound so much better than the kappa tweeters did. I can really crank the volume without killing my ears.
IMO, two and 3-ways aren't necessary with decent dash tweeters.
I started with infinity kappa perfect 6.1 blew those and i went through various speakers after now im on beyma 90m.... the sickest speakers i have ever heard in my life....im still using the stock tweeters and infinity kappa perfect speakers in the rear....I had one of my teachers tune it all last week before a competition.....you go deaf from the precision of music....I cant say what audio company he works for...but dude was beyond impressed with them.
King of NYC
Hmm I just noticed Infinity has a new line. Interesting, I wonder if it is more than just new looks? I see 2 new advantages; the high end goes to 30khz instead of 25khz and the tweeter 3db+ switch is now exposed and not under the grille. I'd say go with the 63.9I.
A-spec steering wheel ftw
i've been wanting to focus on upgrading the speakers for a more full sound,
except after a little bit of reading and searching it looks like the 1011t tweeters are discontinued, as well as the 32.7cf for the center console. also there are way too many posts on door and rear deck speaker replacements, and it ended up just confusing me..
could someone point me in the right direction? It seems my rear deck speakers keep getting blown out, but i usually play my music at most to 30, so I'm looking for a better alternative. Everything in the car is stock minus a basslink.
ok i tried to delete my above post but i guess i tried too late or something. So i didnt realize that crutchfield could sort speakers by make. (https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/els-stock-speaker-specs-size-imped-depth-556521/ also helped)
anyway, I know nothing about car audio so I assume your inputs will be more helpful;
2x Blaupunkt GTx652 6-1/2" 2-way car speakers for the rear
Kicker KS350 3-1/2" 2-way car speakers for the center console
Pioneer TS-T110 7/8" poly dome Tweeters
all that comes out to $160 on Crutchfield; will it be better than the stock? and will swapping to 4ohm speakers stop my rear from blowing out? (i'm not sure if they are blowing out, or what, but every few months it seems the rear speaker "breaks"? and something becomes dislodged and when that happens anything over 8 on master volume makes it rattle and the dealer always ended up just replacing the speaker)
i hate cars SQ is the only thing beyma is..... careful not to beat them they only need a lil wattage and give alot of music in return. ill get u info on the speakers tomorrow....i can also give u a number where u can order them from im in toronto right now and getting things from ny and fl to up here is a bitch.
Does the infinity kappa 62.9i even fit correctly?? I would really like to get these speakers (got a bunch of gift cards to Best Buy) but both the Best Buy website & Crutchfield say it doesn't fit... Does anyone know?? I have an '06 TL w/ navi. Thanks!
For the rear, almost anything will work, in the doors you will need to consious of the depth. G/L
Just about anything? The forums says the install depth is 2 1/8" for the back speakers, while the 63.9i says they're 2 5/16" deep and the 62.9i is the same. According to the specs, the speakers are too deep for the car, but has anyone installed them??
They fit with room to spare.
Beymas ARE HORRRRRRRRRRRRRRRRRRRRIBLE
everyone in my area(bronx ny) has those crappy speakers in their car and they sound like shit..way too harsh...along with electro voice speakers..
akbears15
15
11-05-2015 07:06 AM
Pegon95
09-15-2015 01:54 PM
