Someone please direct me to this wire
Old Sep 30, 2011 | 06:14 PM
08TList's Avatar
i still cannot get my ms8 to turn off with my car for some reason and its getting really hot Can someone please direct me to a wire to hook to the remote in that will have it turn off with the car?
Thanks in advance
Old Sep 30, 2011 | 07:18 PM
Trunk Monkey's Avatar
Coolest A-zine Member
My 3sixty.2 was doing the same thing. It would stay on when the car was off. I took out all my remote/ground/power and made the exposed wire shorter (just so it fits). Make sure it's really snug in that and won't move. After all my troubleshooting, my problem was that little piece on the 3sixty.2 that holds the remote/ground/power was a tad loose. I opened the unit up, made a few mods so it'd fit tight and wallah! See if you can jiggle any or all of the remote/ground/power around near where they go into the MS8 and see if it shuts off or comes on.
Old Sep 30, 2011 | 09:21 PM
08TList's Avatar
i didnt use the wire by itself, i crimped small ring terminals onto them and then removed the screws for the grnd,12v,and rem in and put them back in through the ring so it would be tight
Old Oct 6, 2011 | 02:27 AM
08TList's Avatar
which wire exactly did you use as the remote in?
Old Oct 6, 2011 | 06:47 PM
08TList's Avatar
does our fuse box have any open fuse ports that will turn off with the car? I just picked up some fuse taps and was thinking of going that route
Old Oct 6, 2011 | 06:54 PM
I'll have too look to refresh my mind but I believe its fuse #32 in drivers kick panel. It's the ACC fuse
I would PM Matt (I HATE CARS) since he has the ms8
Old Oct 6, 2011 | 09:09 PM
sddale's Avatar
I believe you are correct...#32
Jul 16, 2017 07:33 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
