Running both sub and 4 channel amp question..
Old Jul 17, 2012 | 11:36 AM
6MTProwler's Avatar
Death Before Dismount
So I am thinking about finally upgrading the factory speaker amp. I already have an aftermarket sub with amp using a line out converter straight from the the original sub location. My question is, will I have to move my LOC to where the stock amp is once I splice into it to run the aftermarket amp??
Old Jul 17, 2012 | 12:13 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Not necessarily. Pick up an amp that is known to accept our low voltage, balanced-diff signal and play without a problem. JL hd and xd come to mind. XD's are cheap right now. What's your budget?
Old Jul 17, 2012 | 12:56 PM
stevemk07's Avatar
I took the post amp signal and it works just fine. If you have a loc already and your amp has pre-outs you could try it out to see if you like it. The processing in the stock amp does make the speakers last but also makes them sound good.
Old Jul 17, 2012 | 11:54 PM
6MTProwler's Avatar
About $400.
All I'm worried about is cutting the signal to the sub once I take out the stock amp.
Old Jul 18, 2012 | 01:39 AM
pohljm's Avatar
Leave the stock amp in for rear fill and center channel.
Old Jul 18, 2012 | 11:20 AM
Originally Posted by 6MTProwler
About $400.
No need to remove the stock amp. Most of us still have it for a few things (HFL, Center Channel, Rears, etc).
Old Jul 19, 2012 | 08:20 AM
6MTProwler's Avatar
Wow I hadn't thought of that...
so just rewire the front then I'm guessing? BRILLIANT!!
Old Jul 19, 2012 | 10:10 AM
jda123's Avatar
Dogmatic Dinosaur
Leave your sub LOC in tact - don't change it.
Tap into the front speaker wires near the stock amp - pre-amp if you want better sound quality (might need a line driver, signal converter, or an amp capable of doing both), post-amp if you want less trouble.
You will need two different sources unless you want a lot of work. The current signal and LOC will not play above 80 hertz, or so, and is not capable of driving components.
I would buy used JL slash amps before you get XDs... might be just me, though, with too many bad thoughts of TMA and e series JL products in my head. Go all the way, or go home with JL - their cheap stuff is still cheap IMO.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Medinak12
Sep 23, 2015 07:11 PM
Pegon95
Sep 15, 2015 01:54 PM
Sep 14, 2015 10:09 PM
