? regarding Navi
Old Jun 14, 2009 | 02:16 PM
usc's Avatar
usc
? regarding Navi
On my '08 base... I've always wondered if this is just a flaw in the software, or if something is wrong with my Navi unit.
When I have it set to "Auto" (adjusting for day time or night time), it never switches to night. It doesn't do it automatically... And it doesn't matter if I have the headlamp switch to "auto" or if I turned the headlamp switch to on/off.
It's the only thing that seems to be wrong with the unit so I never made a fuss to bring it to the dealers to have them check it out. I just assume it's a flaw in the software. I've just adjusted manually myself going into setup and dimming it at night and changing it back to day during the day.
But am I wrong? Is everyone else's Navi properly adjusting itself between day/night time settings when set on Auto?
Old Jun 14, 2009 | 02:23 PM
ifirahse's Avatar
SlammedOnKonis
Did you set the screen to AUTO through the settings? Not the knob by the steering wheel.
Old Jun 14, 2009 | 02:29 PM
usc's Avatar
usc
Yep. Set it to "auto" via the setup button on the console control. I never use the "auto" for the headlamp control (other than the few times I was testing out the Navi to see if both were linked).
Old Jun 14, 2009 | 02:47 PM
ifirahse's Avatar
SlammedOnKonis
Is there anything covering/interfering with the sensor on the dash? Black square on the driver's side.
Old Jun 14, 2009 | 02:54 PM
usc's Avatar
usc
Nope. I have nothing covering the dash. So by your response, I'm assuming yours dim automatically, and something is seriously wrong with mine?
Old Jun 14, 2009 | 03:08 PM
VQPower37's Avatar
when ur headlights turn on the navi screen should automatically dim too ... if u have set it on auto in the nav ... otherwise i would think something is wrong, make sure that you dont have the dash lights set to max cuz then it wont dim with the headlights
Old Jun 14, 2009 | 03:15 PM
Will Y.'s Avatar
Registered but harmless
Adjust the instrument panel light level to 1 bar below "Maximum" with the headlights OFF.
Then turn the headlights on-- the Navigation screen should then automatically go into night mode whenever the headlights activate, either in "Auto" or "On" position.
usc's Avatar
usc
Hm... interesting. That is something that I hadn't tried yet. I may have my dash lights set at max. Thanks for the heads up.
Old Jun 14, 2009 | 03:39 PM
ifirahse's Avatar
SlammedOnKonis
That's the next thing I was going to say. I'm sure your dash is set at MAX. When it's at MAX, the navi screen stays lit up bright, even at night.
Old Jun 15, 2009 | 02:14 AM
usc's Avatar
usc
Just wanted to thank everyone for their responses. You have answered my Navi question spectacularly. "Auto" is now working as intended.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
