Radio cover
Old May 2, 2011 | 01:06 AM
lights's Avatar
Engineer
Radio cover
Hi all,
Can somebody chime in on how to remove the radio front cover off? I've gone as far as getting the bottom part and both sides out, but I couldn't get the top part off. Top side is VERY tight and I don't want to break it. The cover is just clip on on all four sides. Maybe there's another way to take the top side off??
I want confirm this from any acurazinian before I continue.
Thanks!
Old May 2, 2011 | 08:17 AM
dwb993's Avatar
There are screws underneath the trim covering. Move it aside and you will see them.
Old May 2, 2011 | 02:11 PM
lights's Avatar
Engineer
yes, I did remove the screws before I took out the bottom part, total of 2 screws.
but I still can't seem to get the top part out, the clips on it are very tight together.....
am i still missing something??
Old May 2, 2011 | 02:19 PM
dwb993's Avatar
As I recall, there were screws top & bottom. I had to remove a fabric type covering to get to them. Here is a pic:
Old May 2, 2011 | 03:39 PM
lights's Avatar
Engineer
very helpful!! thanks a bunch!!
Old May 2, 2011 | 03:44 PM
lights's Avatar
Engineer
while I'm at this I want to change the bulbs for the shifter indicators (P,R,N,D...). Has anyone done this??
Old May 2, 2011 | 05:43 PM
dwb993's Avatar
Yup. Item C on this diagram. If you go LED, use red or white #74 type bulb.
Old May 2, 2011 | 06:32 PM
lights's Avatar
Engineer
thanks! do you know if there's any filter inside the shifter cover? i'm not sure if changing one bulb will make much of a difference in brightness and it might even turn worst....
I'd like to put one LED behind each letter if possible.
Old May 2, 2011 | 07:01 PM
dwb993's Avatar
Not sure, as I have yet to tear it apart to replace. All of the other bulbs have the blue "condoms" to cast the greenish glow (blue + yellow=green).
You might be able to put a separate LED behind each window, but that would be crazy bright, IMO.
There is a series of articles in the 3G Garage detailing what I and other members have done with LEDs. Search for the DIY series by DeathMetal for lots of info. Here is a taste:
Old May 2, 2011 | 07:47 PM
lights's Avatar
Engineer
yes, i've been following dan's threads.
so far i've been spending my past weekend on everything. I'm maybe half way done.
i'll post pictures once i'm done with everything on my thread. thanks steve!!
Old May 2, 2011 | 08:26 PM
dwb993's Avatar
Its Dave. I can't wait to see what you have done!
Old May 2, 2011 | 10:04 PM
lights's Avatar
Engineer
sorry dave~ yes, i should be done with the radio tonight.
Old May 2, 2011 | 11:30 PM
lights's Avatar
Engineer
umm....got the cover off, now do i take the two knobs off first before i can take the circuit board out? if so, how do i take the knobs off??
Old May 2, 2011 | 11:47 PM
lights's Avatar
Engineer
nevermind, got it out.
Old Jun 18, 2011 | 01:30 AM
lights's Avatar
Engineer
Dave,
I took the two knobs off the radio a while back and I've noticed that they don't have the OEM "feel" as before when you push them in now. It has this clicking noise when you push them in unlike before.
Any suggestion?
Old Jun 20, 2011 | 08:50 AM
dwb993's Avatar
You mean when you turn the radio off (volume) or try to adjust the sound (tune)? Explain a bit more please.
Old Jun 20, 2011 | 11:11 AM
lights's Avatar
Engineer
yes, when you turn the radio on or off. no problem turning the knobs, just pushing the knobs in have clicking noise now unlike the OEM feel before (no clicking noise).
i think the knobs are just now sitting in the right position. maybe a bit more pushed in and the end of the knob is hitting the white plastic piece behind it. but how to adjust them to sit properly?
Old Jun 20, 2011 | 12:48 PM
dwb993's Avatar
Not sure about that one. Mine went back together fine. I do have to remove it again to install the LED board---I plan on getting to that in the next month or so and will let you know.
In the meantime, you can PM Dan (DeathMetal) or madsiick to see if they have any input. I know both of them have had their radio faces off in the past.
dirleton
Aug 6, 2024 08:19 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
