Quickest way to hook up Dice R4
Hey guys,
I ordered this earlier this week hoping to get it installed in my car before the Friday (going on a small road trip). I have read thru the many threads that discuss the install of this kit but my question is...
Whats the quick and dirty way to get this hooked up? I don't care about where the cables are and/or what it looks like.
When I get back, I'll do the proper install for sure.
Thanks for the help!
Jason
Jason
Well, since the DICE has to go "inline" with the XM signal, the quick and dirty and ugly way would be to pull out the right trunk liner, loosen the 3 screw holding the XM box, pull that out to gain access to it, plug in your DICE and route the wires out through the door through the back seat. Not sure how you'll be able to get the wires back out of the trunk liner so the liner can be put back in place though.
There really is no quick and easy way.
That's my
That's my
Man that sucks.
What if I leave my iPod in the trunk? Will it power on with the car? I don't care if it doesn't power off since it gets charged when the car is on.
So the Dice install is from the back? Not like the USA Spec? Man was I off. Haha I guess my proper install will have to wait til I figure out how to do it right!
I was only giving you a quick fix. IMO, the proper mounting is under the console and iPod wire up through the console glove box. You could leave it in the trunk
The connector is the same at the XM box as the back of the radio.
Full of water...
no, the connection should be on the drivers side, so you have to get at it by pulling out the plastic dash/console pieces on that side.
i just installed my USA Spec this weekend, and it wasnt that bad. The hardest part was the actual plugging in of the cord in to the radio. The rest was easy. I have my ipod hookup running in to the top compartment right under the radio.
RedAggie helped me install mine. He di dthe mounting and was tucked very neatly under where the cup holders are, next to the e-brake.., the iPod cable is plenty long from there.
That was how it was in mine. No doubt that any place one wants to install is ok.
True enough that the hardest part is that you have to take your console apart, all the trim pieces and glove box to get access to the screws that hold in the radio, also the info (clock) center has to come out. There is virtually no room behind the the radio when it is bolted in to get to.
FYI, be sure to keep coffee can or freeze bags for all the screws One for the drivers side console.trim, one for the passenger side, one for the golve box and one for the back console piece. The scary part is putting it all back together and having screws left over ... this is speaking from experience.
NTMD8
Dang... I think i should have ogtten the dice, but i pulled the trigger on the peripheral just recently as well...hopefully i won't have the freezing problems like the others. and dang JM we seem to be getting the same mods, HIDs, Ipod connections, lip kit....
Roof spoiler and some yellow fog light bulbs next?
Full of water...
depending on your body size, all that is not necessary.
you only need to remove the drivers side silver trim, and the plastic console piece next to your right leg(which also requires you loosening up the plastic piece under your steering wheel, but that only takes like 5min and there are only like 4 screws and 2 or 3 push pins/clips. there is room to remove the XM connection, it just takes a few minutes to align things in order to re-connect everything, but it can be done without taking apart the whole dash or removing the radio. also, you have to lay with your head by the gas pedal...
https://acurazine.com/forums/showthr...highlight=spec
http://home.usadatanet.net/bclaps/TLAuxcableinstall.pdf
Originally Posted by evnash
i can have my cansole pulled apart in less than 5 mins. its easy once you have done it a couple times
Full of water...
Originally Posted by jmkiang
Always helpful. Thanks man!
Fogs... would be nice but looks like a PITA to install.
not fogs, just yellow fog bulbs, these are mine(very easy to install)
the pics dont do them justice
https://acurazine.com/forums/showthread.php?t=179927
AcuraKidd
09-25-2015 11:18 PM
Eggs999bacon
09-24-2015 10:08 AM
