Project Zune
Modding my TL in
1 Post
Project Zune
Happy New Year Everyone!
Last night I spent five hours installing the Pie X3 and Dom's TVandNav2Go as well as other miscellaneous parts including the Kuda mount with Zune encased in a Belkin Acrylic case for my 2004 Acura TL. I did so to accomodate my newly purchased Zune as well as a Pyle DVD player that I'll be installing sometime later this week (prewired it into the trunk).
I flushed mounted the Pie X3 audio selector and two switches I picked up at Radioshack used to switch between the Navi, Zune, and DVD player near my subwoofer control located at the lower deck lid under the steering wheel.
I wanted to thank everyone that had done these installs as it provided some background information into how to do the install. I'll tell you this, the Pie X3 was a cinch to install with no special tools and so was Dom's unit with provided insructions found on this web site.
Below are some pictures, albeit not the best, you can get the general idea.
Enjoy.
More pictures will follow with my Pyle DVD install in the next week...
Have a good one!
Enjoy.
Have a good one!
Modding my TL in
1 Post
Other parts needed (no particular order):
Kuda Mount
Monster Cable AV for Zune
Flat screwdriver
Phillips Screwdriver
Electrical Tape
Black Tie Wraps
Panel Popper
Power screwdriver w/phillips and drill bits
Wire Grommet
Soldering Iron
Solder
Add a fuse
12 Gauge Wire - 20 Feet
16 Feet RCA Male to Male Video Cable
RCA Female to Female Coupler
Wire Cutters
Wire Stripper
Wire Crimper
Heavy Duty Velcro
18 Gauge Wire for Switches
Switches
Dremel w/cut off wheel
Metric Socket Set
Circle Crimps for Grounding Wires
Glue Gun
Black Hot Glue (special)
Other misc. as needed
Kuda Mount
Flat screwdriver
Electrical Tape
Black Tie Wraps
Panel Popper
Wire Grommet
Soldering Iron
Solder
Add a fuse
Wire Cutters
Wire Stripper
Wire Crimper
Heavy Duty Velcro
Switches
Metric Socket Set
Glue Gun
Got it, I got the answer I wanted. I didn't realize monster had a AV cable that connected to the Zune's stereo jack.
Thanks for the long list.
Kuda Mount
Flat screwdriver
Electrical Tape
Black Tie Wraps
Panel Popper
Wire Grommet
Soldering Iron
Solder
Add a fuse
Wire Cutters
Wire Stripper
Wire Crimper
Heavy Duty Velcro
Switches
Metric Socket Set
Glue Gun
Kuda Mount
Flat screwdriver
Electrical Tape
Black Tie Wraps
Panel Popper
Wire Grommet
Soldering Iron
Solder
Add a fuse
Wire Cutters
Wire Stripper
Wire Crimper
Heavy Duty Velcro
Switches
Metric Socket Set
Glue Gun
Modding my TL in
1 Post
No problem!
As I was doing the install, I noticed my car battery was going (after 2 years) and had ordered one for delivery. However, this afternoon, the car didn't start. The battery didn't last that long. Long story short in 2 hours I'll be picking an Optima up from Sears 34/78 - prepaid, cost me like $194 bux though. Ouch. I didn't really have a choice though. At least it will be beneficial going forward with all my mods.
Have a good new year everyone!
Looks good, glad to see other people leaning towards the zune. Quick question, what did you use to hold the zune on the mount? I dont see the cradle that you can attach.
Hooksta - you can use the same method but only videos will show on the screen. You can not see anything else as the ipod doesnt support it yet. This is the reason I switched to the Zune.
Modding my TL in
1 Post
Zune is in an acrylic case. On the back of this case and on the Kuda mount is heavy duty velcro. The soft side is on the acrylic case so that when I am mobile with the unit, it is nice and clean as well as no issues in pockets, etc. It makes for a clean install and does not mess with the actual Zune itself.
WOW!!! Great work man. I'm going to have to come by and check it out. Maybe when it gets a little warmer out, you can give me some tips on how to do this on my TL!
cycdaniel
12-17-2019 10:58 AM
