Popping noise when using HFL?
Old Jan 11, 2006 | 10:00 AM
maluskills's Avatar
Mofo
Hey everyone
Apologies in advance if theres a thread out there already for this, but I couldn't find one.
I am having this problem of everytime i use my HFL (which is ALOT) of right before it rings, I hear two popping noises (mini versions of speaker popping noises).
Is this normal? I am thinking about taking it to Acura but I don't want them to blow it off as normal.
Old Jan 11, 2006 | 10:14 AM
Cyph3r's Avatar
I get the popping noise when I make a call using HFL, but not when I receive calls or during a call.
Is that what you notice as well?
Regards
Old Jan 11, 2006 | 10:28 AM
maluskills's Avatar
Mofo
Regards
Yup - exactly
If i remember i turn down the volume really quickly until it starts ringing b/c I'm scared it might actually blow out the speakers..
Old Jan 11, 2006 | 11:03 AM
rbf351's Avatar
Registered User
i think its "normal" i know mine does it too
Old Jan 11, 2006 | 11:12 AM
1995hoo's Avatar
Keep Right Except to Pass
Is the sound similar to the slight crackle you get when you put the needle in the groove on an LP that hasn't been cleaned recently? If so, I believe it's normal. Mine does it when I dial out. It's probably some sort of static or other interference. Bear in mind that the Bluetooth is a wireless connection.
Old Jan 11, 2006 | 11:57 AM
Cyph3r's Avatar
Ok, as the others have suggested, I get the noise as well on '06. When I first used it, I thought it was a little strange, but it happens every time I make a call, so I'm assuming it's just normal.
Now the "volume" of the popping is pretty consitently the same regardless of the volumne of the music I was playing before, so I wouldn't think you'd be blowing any speakers away...
Regards
Old Jan 11, 2006 | 12:16 PM
rkphillips's Avatar
Where in the car is the phone? I can get this if the phone is near the radio, such as in the compartments at the bottom of the center stack under the radio. I do not get it with my phone clipped to my belt, in a briefcase in the backseat, etc.
Old Jan 11, 2006 | 03:14 PM
maluskills's Avatar
Mofo
Thumbs up
For me, I definitely hear a difference when the volume is lowered and when it is higher...
I always have the phone either in my pocket or in the cup holders and have heard it everytime...I will try leaving it in the backseat and see what happens
Thanks everyone
Old Jan 11, 2006 | 06:16 PM
JustinZ's Avatar
it is NORMAL
its not the TL's fault - its part of bluetooth and youll hear it from ALL bluetooth audio devices I guess you guys havent tried any BT head sets - sounds the same
Old Jan 11, 2006 | 06:21 PM
Cyph3r's Avatar
I was playing around with the HFL today and actaully had the phone in view (usually it's on my waist) and I noticed that each time the display on my E815 changed, I heard the popping noise each time a new message appeared.
It first said "Calling <number>..." and I heard a pop, and then it said "Connected <timer>" and I heard another pop.
That's my explanation.
Regards
Old Jan 11, 2006 | 08:15 PM
Actuary's Avatar
18,000mi. 29000km
I heard it's all GSM phones does that. But BT theory makes sense too.
It happens near any speakers not shielded
Old Jan 11, 2006 | 11:36 PM
hoTLanta's Avatar
If I listen closely to my phones speaker(Moto V710), it makes that sound when not even using HFL. I believe that the TL's HFL amplifies this sound, and that this is a normal operation.
Old Jan 12, 2006 | 02:33 PM
Fatal_Ice's Avatar
I have a similar issue on only outgoing calls where is crackles really bad and the other person cant hear me. I have narrowed it down to what the issue is I just don't know what to do about it. I turns out that on occasions when I make outgoing calls, the bluetooth down fully pair with the phone because during the crackle, I can hear audio thru the car's speakers, but when I grab the phone and blow into the mic on the phone you can hear me. Usually when a phone is paired the earpiece and mic are disable. I just don't know what to do now.
Old Jan 12, 2006 | 07:52 PM
Opti's Avatar
I have this problem with my new Verizon Motorola RAZR v3c, but did NOT have this problem with my previous phone, a T-Mobile Nokia 6600.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
