Plz help me out
Plz help me out
hi i got a program called Ulead DVD MovieFactory 4.0 i did burn the dvd-a but when i went to the audio section of my car it started reading the dvd-r and it said that dvd-a disc but then it just turned off my car audio and the disc came out can u plz help me out....thanks...........
Originally Posted by Toronto-TL
The program will NOT make DVDA disks, only DVDV.
Check out this thread if you haven't already https://acurazine.com/forums/car-talk-5/my-roommates-vw-gti-121358/
To clarify, there are two versions of Ulead DVD MovieFactory 4.0: the standard version and the more deluxe "Disc Creator" version.
Here is a link that compares the two.
http://www.ulead.com/dmf/compare.htm
Also, after browsing Ulead's website, I think the standard version is the only one available for trial download. From Ulead's System Support Center, updates will not work on the trial version (http://www.ulead.com/tech/dmf/dmf.htm).
I didn't go through the trial download, so I can't help you there. If you think its too much of a hassle, maybe you are better off trying one of the other mentioned alternatives. Personally, I've found Disc Creator to be very easy and straight forward. Adobeman recently updated his scripts to make it more straight forward. Not sure what the current status on it is, but you can find out with a search.
On the contrary to the manual, DVD-R seem to work better than DVD+R.
Hope that clears things up!
LeonCL
Feb 2, 2005 01:27 PM
