Please help with sub and amp.
Old Jun 20, 2011 | 07:48 PM
03gjb's Avatar
5th Gear
hello i have a acura tl type s with the navi. and just had a ls7 12" woofer with a 1000 watt amp. and when ever i put the tranny in park or drive or open a door the woofer blares and goes off even if the audio is off any ideas?
Old Jun 20, 2011 | 09:07 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Sounds like someone had no idea how to install a amp/sub. First off, have you checked the wiring? Are you using a LOC?
Old Jun 21, 2011 | 12:36 AM
Nick337's Avatar
Disconnect your ANC system. Under the center channel speakerthere is a silver box, unplug it and it should stop.
Old Jun 21, 2011 | 12:45 AM
csmeance's Avatar
and recheck your wiring. It sounds like there may be a loose ground wire as well.
Old Jun 21, 2011 | 09:32 AM
Rock2534's Avatar
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/big-problems-need-help-sub-noise-cancellation-609759/
Assuming you have it wired correctly, this should fix your issue. I had the same thing a few weeks ago, disconnected the rear ANC microphone and it has been fine ever since.
Old Jun 21, 2011 | 10:54 AM
03gjb's Avatar
5th Gear
i read all the things about the anc but im confused on how to disconnect it wether to go threw the center speaker and unplug the box or unplung the things in the 2 dome lights does anyone have instructions on how to do this? and any pictures?
Old Jun 21, 2011 | 01:13 PM
Rock2534's Avatar
Refer to the thread I linked....it took me 5 mins to disconnect the rear one. That solved the problem so I did not disconnect anything else. Use a small flat head screw driver and pry off the clear light covers. Place the screwdriver in the middle where the two lenses meet, they will pop right off.
There are two screws to unscrew and the whole housing will pop right out. Use a flashlight and look up in the roof liner, slightly left of the dome light cutout and you will see a green connector. Squeeze it from the top and it will pop right off. Then just put the dome light back on and you should be set.
Start with the rear, if it resolves the issue, no need to do more.
Old Jun 21, 2011 | 03:27 PM
03gjb's Avatar
5th Gear
got it fixed thanks for all the help
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Medinak12
Sep 23, 2015 07:11 PM
Pegon95
Sep 15, 2015 01:54 PM
mattrush78
Sep 1, 2002 03:35 PM
97AcuraCL
Jul 4, 2002 11:11 PM
