Please Help - Assistance from Technical point of view
Old Nov 11, 2014 | 09:16 PM
QuickTL07's Avatar
Exclamation Please Help - Assistance from Technical point of view
OK Guys here it is..
I want to redo everything in my car including where OEM NAVI radio is located. I want to go with either car computer, with 8" Touch screen or maybe 10" or I might go with Windows Tablet all together.
My car came with the Navi system, I just purchased from 2005 non navi disply with left and right heat controls (Passenger and Driver Side Controls)
My main question is, since i have only the display which is this:
http://www.ebay.com/itm/231193788051?_trksid=p2059210.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Will the connection work from NAVI to This non NAVI electronic board? my main thing is the heat and cooling controls to work....
I definitely don't want to damage my NAVI system, I will put that away in safe place in-case i need to bring the dash back to stock.
Old Nov 11, 2014 | 09:21 PM
QuickTL07's Avatar
Please help me out guys,
Worst case I will have to take the Navi apart and see if all the cables are the same and test everything make sure the non navi works with heat controls, but i honestly don't see why it wouldn't.
Please put your input in if you guys know of anything,
Old Nov 11, 2014 | 10:05 PM
QuickTL07's Avatar
After doing some research, I came across this,
Back of Navi Unit:
2007 08 Acura 3 2 TL Navigation GPS LCD Display Touch Screen Monitor Tested | eBay
None Navi unit, Disply Only:
http://www.ebay.com/itm/04-06-Acura-TL-Display-w-o-Navigation-Climate-Control-Screen-39050-SEP-A1-OEM-/390972705664?pt=Motors_Car_Truck_Parts_Accessories&hash=item5b07ca0b80&vxp=mtr
Old Nov 12, 2014 | 02:27 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Sounds like what you really want is to retrofit a tablet PC in your dashboard. The easiest way to retain the HVAC functionality is to leave your current nav stuff there, and just replace the screen with a tablet PC.
Check these threads out:
https://acurazine.com/forums/audio-b...s-pics-891106/
https://acurazine.com/forums/audio-b...ve-one-902733/
https://acurazine.com/forums/audio-b...ration-852090/
Old Nov 12, 2014 | 09:20 AM
QuickTL07's Avatar
Thank You for the links, I have looked at them before as well, I try to do as much of my own research before reaching out to anyone.
I so don't want to use my NAvi system, that's why i bought the other stuff so i could re-use it in my build. I will have to pull my dash apart and try it myself self to see how its going to work. worse case, it wont work ! and I will have no choice but to build it around the stock Navi.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
