"Phone Setup" command doesn't work
Old Feb 8, 2005 | 11:56 PM
dinot's Avatar
Hi all,
I was trying to setup my Nokia 3650 tonight. I can't for the life of me to get the voice recognition to understand the "Phone Setup" command. Unfortunately this is the first darn step. I speak very clearly and I typically don't have problems with other commands. Is there any way to manually enter Phone Setup? I get the following "guesses" by the system when I say "Phone Setup"
- Setup (Enters the regular setup)
- Find Nearest Restaraunt
- Set fan speed 7.
I was getting pretty frustrated. The phone has bluetooth turned on. I am not sure what is meant by discovery mode, but I have set the phone up to be seen by other devices. I can connect to the phone via bluetooth with my Palm Tungsten T3 and surf the internet, so I know that the phone's bluetooth is working.
After working on this for around half an hour I also found that the system doesn't understand curse words either.
Any help would be appreciated.
Thanks,
Dino
Old Feb 9, 2005 | 09:59 AM
xristos's Avatar
.:HALCÓN DE LA NOCHE:.
First, the car should be in "P" (park)
Maybe you're pressing the wrong button on the steering wheel. Try pressing & then releasing the top button w/ the pic of a phone on it & say "phone setup". If you are pressing that button, then there's something else going on w/ the HFL system that won't let you get to the phone set-up.
You can also go to your salesperson & have them help you out w/ your problem. Let us know what was the problem. Good luck.
BTW, the first time I paired my phone it was pretty easy. After I replaced my phone under warranty, I paired the new phone again w/ no problems. The second time I went into "phone setup" I must have missed the options it had the 1st time like: prompt or ring for call waiting, male or female voice, & a few others I can't remember. I currently have "ring" to notify me of call waiting, but I need to try out the "prompt" & see which one I like better.
Old Feb 9, 2005 | 11:36 AM
Brewmaster's Avatar
I'm Baaack!
the responses you're getting are from the NAV handsfree, not the Phone handsfree.
Should be an easy fix ...
This used to happen to me a lot when I first got the car, if it responds with prompts for the Nav, Climate Control, or Radio, you're on the wrong button.
Old Feb 9, 2005 | 05:53 PM
dinot's Avatar
Thanks!!! I was indeed pressing the NAV talk button. Once I pressed the right button, it took me all of 2 minutes to setup the phone.
Dino
Old Feb 9, 2005 | 06:23 PM
jafo's Avatar
Team Anthracite Member
Dino, this happened to me when I setup my first phone pairing. Same exact thing... The lady kept barking "Pardon". Or my AC would go full blast. Haha...
Old Feb 9, 2005 | 06:37 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Ditto here, too.
I was trying to speak so clearly and I was even putting my head nearer the mirror.
Old Feb 9, 2005 | 09:16 PM
dinot's Avatar
Yeah I felt goofy about it. I speak fairly clearly and the system understands everything I toss at it, and to have it not understand two words.....duh?
euxaristo xristo
Dino
Old Feb 9, 2005 | 09:24 PM
jafo's Avatar
euxaristo xristo
Dino
I felt like an idiot too... Once I realized what I had been doing. I was literally sitting there for 5-10 minutes with it saying "Pardon" or blasting the AC. Felt like a goober! Paired my wifes phone a little while later in no time. Haha. )
Old Feb 13, 2005 | 11:46 PM
niarbdab's Avatar
Professional Somnabulist
I did that same damned thing!
I even had others sit in my car and try for me...I looked like an idiot.
AndrewS
19
Mar 14, 2024 06:59 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
