Outside temp display slow to update
Old Dec 7, 2005 | 09:20 AM
AMIC's Avatar
Fightin' Texas Aggie
On these past few colder mornings, I have noticed that the outside temp display takes forever to get down to the correct temp, in fact sometimes it never does on my short commute to work. I keep my car garaged and when I get in it always shows around 60 degrees. Then I pull out into what I know is close to 40 degree weather and it slowly starts to go down a degree every minute or something like that. It takes me about 7-10 minutes to get to the office and by the time I get there it will say something like 55.
Anyone else experience this? It seemed to do a better job in the summer.
Old Dec 7, 2005 | 11:17 AM
vp911's Avatar
There was a TSB for the temp display - was your car affected by this? I am not sure if the TSB was for this particular issue you are describing, but it may be worth looking into
Old Dec 7, 2005 | 11:39 AM
HiTEC's Avatar
Mine as not as slow as your. My garage is heated and I keep it around 50f. So when I pull out from my 50F garage into the 10F weather, it take my display usually less than 5min to read correctly. It probably actually get there in about 2min.
I have a 06, so if there was a TSB I assume mine is corrected.
Old Dec 7, 2005 | 01:01 PM
AMIC's Avatar
Wasn't the TSB for it going blank with the dashes?
Old Dec 7, 2005 | 01:14 PM
vp911's Avatar
^ It may have been, I don't remember which is why I asked to see if that was it. I know when I had my TL it updated the temp pretty quickly - the RL does the same now.
Old Dec 8, 2005 | 08:49 AM
AMIC's Avatar
It looks like there is a TSB for the temp display being off by more than 3 degrees. However, it's not worth having the dash taken apart. Mine does actually get to the right temp eventually. I'll just live with it.
Old Dec 8, 2005 | 03:36 PM
rgorsk's Avatar
I just had my '05 serviced and they did the TSB fix for the three dashes for the outside temperature. Now it seems to be much more reactive to changes in temperature (and it seems to be pretty accurate). Before the fix it would take forever for the temperature readout to adjust when I pulled the car out of the garage.
A sidenote. After the fix I have a funny smell whenever the heat goes on. It seems like a cross between engine coolant and burning rubber (both of which are scaring me).
Old Dec 9, 2005 | 02:23 AM
Filip75's Avatar
SSgt, USAF
yeah, mine (05) was fixed too, and it usually takes about 2-3 minutes to get to the real temperature reading.
Old Dec 9, 2005 | 07:48 AM
Ron A's Avatar
Administrator
Just for your information, here's a thread about the temperature sensor logic and calibration procedures. The procedures may have changed slightly since this is for the 04 model, but the explanation should still be good.
Old Dec 9, 2005 | 08:59 AM
AMIC's Avatar
Thanks Ron.
Old Dec 9, 2005 | 09:16 PM
mbwmn's Avatar
i have this problem. where is the service bulletin?
Old Dec 9, 2005 | 10:10 PM
Ron A's Avatar
Administrator
It's in the 3G Garage. This link will get you close but you'll have to do a little work for yourself.
But the TSB is only for the 2004 TL.
ITSJESTER
17
Dec 6, 2018 02:29 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
hashbrown
Sep 29, 2015 12:13 PM
thegipper
Sep 28, 2015 01:01 PM
Froid
Sep 27, 2015 06:16 PM
