Occassional Skipping on the USA Spec PA11-HON2Y
#161
Originally Posted by dennisil
Pie Makes an A/V cable adapter that sends audio and video through the botom of the ipod and allows for the ipod to charge via any 12/v connection, it comes with the in line fuse all you need to to do is wire tap this somewhere and your good to go. sure you cant change songs from the sterring wheel but you cant hand the backseat passangers your stering wheel either ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![](http://lib.store.yahoo.net/lib/logjam/avpoddia.jpg)
#163
Wife's 5G iPod works without problems ...
I was having a bunch of problems with my HON2Y and my 3rd gen iPod, but we used her 5G on a recent road trip and it worked flawlessly. Haven't given it back since.
#165
I honestly think that this is a lost cause. Everytime I call USA Spec, they say that they're working on it but they've been saying that for quite some time now and I don't think it's a top priority for them there to be fixing this skipping issue.
I actually just re-ordered the old unit (HON2) from them because even though this was a buggy version in itself, I remember it definitely didn't have any issues with skipping.
#166
#167
I'm somewhat disappointed a fix hasn't come out yet. Has any other alternative come out that lets you control it form the steering wheel, yet?
Does anyone else think the problem might be loose connections at or inthe little box? Maybe a loose connection inside?
#168
Originally Posted by AMROCKS
I thought that the HON2 and the HON2Y was the same unit just comes with a different harness. The first buggy unit was the HON and then they offered the HON2 which is the updated of fixed version of the HON. The Y was added to the harness so you don't have to get the Y adapter and that is sold as the HON2Y. I could be wrong but I think that this is the way it went. Either way USA-Spec will never get anymore of my money!!
#169
It might be an issue with a loose connection but that's pretty unlikely since most of the people on here have been experiencing the same issues.
#170
Here's my update...It's been about 3 months now and the USASpec has not skipped once.
I've been trying to listen to my iPod a lot lately just to record how many times the skipping would occur. I have had 0 the past 3 months.
So I really don't know what to say. It has a mind of its own.
BTW, I have a 5th gen 60GB iPod.
#171
#173
well, i DID have the problem (post #17). it just seemed to occur less and less before going away totally now.
#174
Update for me,
My left side audio issues are definitely still fixed (post the cable swap) but I still get the skipping multiple times a day.
Of course I am living with it but I really would like a fix (not holding my breath though)
#175
Originally Posted by brianp6621
Update for me,
#177
Trucki!!
how did you fix the left side audio issues? I've been trying to figure that out forever!
#178
I just thought I'd chime in and say that I finally got the USASpec and installed it yesterday. I've only had it in for a day, but everything seems fine so far. No skipping, no audio issues.
I was a little skeptical myself, but I decided to go for it anyway. I love being able to change the songs with the steering wheel controls.
By the way, with the help of the instructions in the Garage, this was one of the easier installs to do. I didn't need any special tools and was able to unplug and plug the adapter in with just my hands. It probably took me around 45 minutes to do it. Piece of cake!
I'm happy with it so far!
-Brian
-Brian
#179
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
https://acurazine.com/forums/showpos...&postcount=151
#180
well, after using a friends POS fm transmitter (Monster) for a few days, I decided i'm going to give this a shot.
thanks to all for the good info.... I see some places selling cheaper than others... hmmmm.....
#181
Originally Posted by lembowski
Left side issues is when the audio will sway in and out playing only on the left channel. I had this issue with the Hon2 that you say your ordering (the old one) CI upgraded me to the new Hon2y and all my problems stopped. No skipping, no audio sway. Been perfect for close to 3 months now ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
any ideas on how to get rid of it without going to the HON2y unit?
#182
I had the HON2y and I remember it did get rid of this problem but what I didn't like was the other bugs that it came with like the skipping. Because of this, I went back to the regular HON2 unit and have been using it since. I haven't had the skipping problem but that left side audio problem is still there.
Several people, including myself, have fixed the left side issue by replacing the cable from the back of the HU to the HON unit. I was never able to determine if this was a defective cable issue or just something that got resolved by completely reinstalling that cable, but it worked for me (and others)
#183
-Brian
-Brian
![Pissed](https://acurazine.com/forums/images/smilies/pissed.gif)
I hope they fix this someday.
-Brian
#184
6th Gear
I'll chime in too.
I purchased a HON2Y unit from Crutchfield, and installed it today in my 2004 TL w/ NAV. Everything sounds great, and after about 45 minutes of use, I have not encountered any skips with my 60G iPod. I'll keep my fingers crossed that it continues to perform smoothly.
What's interesting is the HON2Y unit I received has a note saying that USA SPEC replaced the "Playlist" mode with "Hybrid" mode. It allows you to use the buttons on the radio to select your predefined playlists as usual, but also allows direct control with the iPods controls. The iPod itself is not locked to "ok to disconnect." Very cool!
#185
I've been running the HON2Y for several months. I had no skipping during much of the first week after install, but now it skips quite a bit. My commute is about 30 minutes each way. Every day it skips. Skips always come in pairs, about a seond apart from each other. The second skip is longer than the first, but neither one lasts more than a second. I can count on about two sets of skips in the morning and again in the evening.
Maybe it's my imagination but it seems like the skips often come after I have changed tracks with the steering wheel controls, but not always. This past week it also seems like the skips are getting a bit longer and more pronounced.
The sound quality of the direct cable connection is so much better than FM transmitters or cassette adapters, that I'm enduring these annoyances without too much complaint.
#186
hon2y
Help!! My ipod locks itself on "ok to disconnect" then sometimes the screen goes into the normal menu mode on the ipod. how do i get it to the menu mode quicker? id rather control my ipod from the menu mode. thanks
#187
6th Gear
delrey737,
Is your HON2Y in hybrid mode (dip #2 on, in the newer units)? If so, the manual says that during the first 30 seconds of operation, the iPod will flip back and forth between the "ok to disconnect" screen and the normal menu. After that, the unit should function fine.
#188
Registered P.I.M.P
But it is definately a problem. I guess the track skipping is a big thing because I'm constantly changing tracks.
#189
^I've had the same symptoms. If it skips, it's always two really close together. On the second skip, it always gets knocked out of random mode (and the track counter resets) and I have to hit the random button on the stereo to get it back to random mode.
Also, I do have the audio shifting to the left problem. This must be a cabling issue because I have to jiggle the cable under my seat to get rid of the problem. The shifting seems to happen a lot when the road is bumpy or I am making a hard turn. I wouldn't have expected a solid state device to be this sensitive to movement.
#190
me too....
I installed my hon2y yesterday, the install was a piece of of cake thanks to the great instructions in the garage
My unit did the 2-skip thing about 2 minutes into the first time operating it. I knew about this issue from reading it, and when I heard the first skip I thought , ok it was just a fluke.. then 1-2 seconds later it did it again.... It has not done it since, but i've only used it ~30mins. I really hope this is not a re-occurring issue.....
On a positive note, the thing sounds fawking amazing!
![Alf](https://acurazine.com/forums/images/smilies/alf.gif)
#191
Oakland Team Nighthawker
I'm looking to buy this and have it installed in the Oakland/SF area.
Any suggestions for folks who can do this well? I looked at the posters in this and related threads and didn't see anyone from the bay.
#192
I'm gonna get rid of my USA Spec adapter for now and try the new DICE adapter that's out there. Apparently it has Text display capability and there haven't been any reported issues with skipping or sound. Everyone should try it
#193
I'm gonna get rid of my USA Spec adapter for now and try the new DICE adapter that's out there. Apparently it has Text display capability and there haven't been any reported issues with skipping or sound. Everyone should try it ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#194
I'd consider it if I could keep XM but I'm not sure I'm ready to give it up.
#195
For those that have encountered skipping problems, can you list what iPod you have? I've read the entire thread and it's not clear if the skip only happens on certain iPods vs. all iPod types.
I have a 5th Gen. Video iPod and am considering getting this adapter (as I want to keep XM) but am a little concerned about this skipping problem (otherwise, it sounds like a reasonable solution).
Thanks,
-Brian
2004 TL, Nav
Thanks,
-Brian
2004 TL, Nav
#196
08 MDX, 04 TL (sold)
04 TL, 5th gen 30GB Ipod, i experience the skipping.
I personally feel it is only a minor nuisance. I will still purchase the unit again even knowing about this issue. It happens rarely and is such a brief blip that the benefits far outway this nuisance.
#197
07 TL Type S, 5th Gen (Video) 60 GB iPod, I experience the skipping, it's actually a skip followed by a 1 second pause of the iPod, rather annoying. It's very random, I can go a couple hours without a skip, then have 5 skips in a 30 minute period...
#198
By the way . . . I emailed USASpec just to let them know that there are still people out there with the skipping problem. Here's there reply:
"We're still working on a software update for the TL skipping problem. Current ETA for the solution is about 1 month. I'll put your name on our call list and will contact you once the new software becomes available."
We'll see how long 1 month turns into.
-Brian
-Brian
#199
190 plus posts
Alright this skipping is starting to really bother me now.
I don't use or plan on using XM.
Currently I have:
06 TL w. Nav
5th Gen 30Gig Ipod
Hon2y adaptor
I use the direct mode
I like everything about the setup minus the skipping. Any suggestions for another product that gives the same funcitionality minus the skipping?
Thanks,
Scrap
Currently I have:
06 TL w. Nav
5th Gen 30Gig Ipod
Hon2y adaptor
Thanks,
Scrap
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
#200
i wish the pie X3 i have was controlled through the steering wheele but you guys say the skipping issue sucks so bad i dont mind using th eipod to change videos and songs, oh yeah and the pie X3 even offerd a special av-pod adapter that lets me play audio and via - doms unit i play video, al while it charges the ipod, but no text and no way to change songs unless you use the ipods tricky wheele, volume is the only adjustment i have from the stering wheel.
