No subwoofer, what to add?
The original owner of my 2006 TL did not care for music, so he didn't purchase the subwoofer. I pulled back the trunk liner on the right side and I didn't find an amp or any other wiring near that corner.
I would like to add a subwoofer to the rear deck. What do I need to plan to purchase to do this?
Thanks (BTW, for those that would suggest that I put a box in the trunk, I'm sticking with the speaker in the rear deck plan.)
An easy check will be to pull the trunk liner down an inch or two to see if your sub is there. I'll bet it's in there. If not, you can get an OEM sub for cheap here on the BM or even through Acura it's not a huge expense.
I don't suggest getting an aftermarket sub for that space, because it would have to be an open air 2ohm sub, which only a couple of manufacturers make. The OEM is built to fit into your current wiring. Anything more powerful than OEM will also rattle the heck out of your deck.
Duh! I looked again at the onscreen control for the sub. I thought that it was grayed out but that's just its look. I was able to select it and push the control over to the right for maximum output of the sub. I had it the whole time without knowing it. No flames please.
I've had the car a year and a half. Somewhere along the line, I saw that dimmed sub control and thought that I didn't have one. I recently ordered one of the iSimple units (iSimple ISHD571) so that I can hook up my Android phone to my car's stock stereo. I plan to put a 3.5mm jack in the deep well under the armrest and plug my phone in there.
Now that I "found" my sub, I'm good with it. Maybe somewhere down the road I'll think about upgrading it, but I don't want to give up any of my trunk space for a box. With a wife and two kids, the trunk gets full quite often.
emailnatec
29
Sep 28, 2018 04:27 PM
soupi
14
Nov 15, 2015 11:15 AM
kb1rl
Sep 30, 2015 10:17 AM
