New Sub+Amp Installed finally!
Finally hooked up my Alpine Type R and Alpine Mrp-m500.
It seems like it should be louder. but i dont have my amp turned all the way up. Since the Amp is 500 watts and the sub is 600 it should be ok to turn the amp all the way up?
I have it in a sealed box maybe i should get a ported?
Also when i turn my headlights on the audio screen gets lighter and the navigation loses its color. Should i buy a capacitor?
Dogmatic Dinosaur
Which way do you have the box pointing?
Give it some more juice, but don't let it distort.
Do your big 3. You should not need anything with a 500W amp.
i got it pointed towards my trunk. i tried to point it through the whole in the seats but the plastic lock thing shakes and rattles.
could be box. prob shitty box. head unit sub setting almost up and the bass almost all the way up
I've never needed a cap even when I was feeding my 12W6s 1,100 watts in their sealed box. Maybe if that was 1,100 watts from an A/B amp but just about every sub amp is class D now. I'm currently using only 200 watts total for both subs and it would be silly to run a cap for that kind of power. It uses less power than the rear window defroster and it's not constant.
Dogmatic Dinosaur
I'd rather be golfing
Do you have any type of sub control knob? I have one on my 3Sixty, and I'm glad I do. I just upgraded my sub amp, running an Alpine MRD-M605 at 2 ohms on (2) RF 12's (getting 300w each) in a sealed box. Incredible bass! My subs are pointing up so they fire into the rear deck. My biggest problem now is the dreaded rear shelf rattle. I'll be breaking that down soon and adding more sound deadener to that area. I get a lot of rattle right where the cover meets the rear window.
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
