New Door Speakers-Which ones?!
Old Jun 3, 2010 | 10:10 AM
robchimo's Avatar
I am buying new door speakers for my 06 today. I have it narrowed down to the Infinity 6022i's or the Alpine SPS-600. Any suggestions on which ones to buy? They are about the same price. Thanks!
Old Jun 3, 2010 | 10:31 AM
eggyhustles's Avatar
Neither
Old Jun 3, 2010 | 11:13 AM
robchimo's Avatar
lol ok. any others that can be purchased at best buy?
Old Jun 11, 2010 | 05:36 PM
NCTL05's Avatar
Middle Finger anyone?
This is what I would do. I would cruise crutchfield.com and start comparing speakers. Usually the mounting depth will determine which speakers you can and can't use. You also have to be aware of the impedance of the speakers and compare that to the stock speaker's impedances. They should be the same. Personally I really like the Rockford Fosgate Power series speakers because I listen to alot of Rock. They also have an aluminum cone so they'll never ever blow out with the stock amp. Infinity is a good brand if you like a super clean sound.
Old Jun 11, 2010 | 07:33 PM
Rafiton's Avatar
I had some infinity Reference speakers on my last car and they sound it awesome
Old Jun 11, 2010 | 07:39 PM
robchimo's Avatar
i went with the infinity's but they didnt fit well in the door and i didnt want to have to cut away anything to make then fit. I ended up buying some Polk db651s and the fit and sound perfect.
Old Jun 11, 2010 | 10:00 PM
ParaSurfer1979's Avatar
Infinity or jbl. bth are 2ohm like you need if running off the stock amp.
Old Jun 11, 2010 | 10:36 PM
FR3SH_TL01's Avatar
6th Gear
I would go with none on my 1st generation i have the bose speakers still but modified with a nice pioneer single din radio which i could control the freq. And if you turn the hpf(high pass filter) on to 125hz it would sound beautiful with the mid range on. But in your case if you want to get new 1's i will go with audiopipe bullet point mid range speakers or o2's(oxygen audio) or whip audio's with some tweeters 6-12 inches away you will get pure voice out the speakers obviously with a 4-channel amp and you could also add a 8"inch midrange speaker and replace the sub hole in the back.
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
