Need help w/ navi
Old May 9, 2010 | 07:51 PM
hmian00's Avatar
Need help w/ navi
Hey guys, 2 days ago i started my car and the OK navi screen didn't show up instead it showed the ACURA logo NAVIGATION SYSTEM with picture of space in the back. While driving the screen goes off and turns back on like its rebooting and sometimes it comes to the screen where i need to enter the password.....problem with that is....it wont accept any numbers except for the first one. One time the other night it did accept it after pushing a little harder and the whole thing worked till i got home and next day didn't work again. I tried cleaning the cd but no success. Please help...thanks
Old May 9, 2010 | 08:10 PM
hmian00's Avatar
anybody...?
Old May 10, 2010 | 09:57 PM
fkirkpatrick24's Avatar
My wife's 04 TL just started doing the same thing a couple of weeks ago. I looked around and several places said to take off both battery cables, touch them together for a minute or so and leave the cables off for 15 minutes and it will reboot the system. I did this and it came back on and said rebooting but then went back to the same problem as before. Please anyone with any info or ideas help us out.
Old May 11, 2010 | 09:57 PM
NPO1026's Avatar
9th Gear
Never had this happen but I would try to disconnect the battery for a reset. Also, make sure nobody took the disc out that goes in the trunk.
Old May 11, 2010 | 10:03 PM
shadowkahn's Avatar
If the battery reset doesn't work, take the disc out and clean it, then put it back in. If that doesn't work, see what happens when you hold the map, menu, and cancel buttons down together for 5 seconds. If it goes into the diagnostic screen, run the diagnostics, but do NOT change any settings. See if anything comes up with an error.
Old May 12, 2010 | 02:25 AM
hmian00's Avatar
Already tried cleaning it and disconnecting battery....I haven't done yet and I tried to get the diagnostic menu but that didn't work either.....any one know the cause to this....I'm pretty sure someone here had this problem and fixed it ....help us please
Old May 12, 2010 | 11:30 PM
gmeier's Avatar
I am having the same problem and need help also.
Old May 14, 2010 | 07:24 PM
hmian00's Avatar
any mods know the fix to this?
Old May 15, 2010 | 12:05 PM
jr27's Avatar
2005 AM at/navi
i just tried running the diagnostics. which one should i run it has many sections.
Old May 15, 2010 | 01:50 PM
hmian00's Avatar
i can't even get to the diagnostics screen. I ordered me the new update....hope that works
Old May 17, 2010 | 05:17 PM
hmian00's Avatar
tried everything nothing works
bought the new update dvd --FAIL
unplugged the battery---------FAIL
disconnected the dvd unit in the back---FAIL
idk y but the nav screen will not accept more then the first number and then it'll restart it self...HELLPPP PLEASEEEE
Old May 17, 2010 | 06:44 PM
Will Y.'s Avatar
Registered but harmless
Sounds like you'll have to pull the trunk drive and ship it to Alpine w/$150 for repair.
Do a search for the correct address; several members have had to do that, IIRC.
G/L.
Old May 18, 2010 | 03:47 PM
hmian00's Avatar
whats IIRC?.....and any idea what the issue is? could you guide to me the correct the site or address or something?
Old May 18, 2010 | 06:33 PM
Will Y.'s Avatar
IIRC = If I recall correctly
See posts 32 and 61 re: Alpine address in this thread: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/dvd-disc-reading-error-3g-garage-i-001-a-690561/
Call Alpine to confirm the shipping address; it has a number of service centers.
Old May 18, 2010 | 06:54 PM
hmian00's Avatar
thanks WILL.....and i will call alpine tommorw.....im just mad at the fact that it happened out of no where....
Old May 18, 2010 | 07:05 PM
hmian00's Avatar
when you unplug the dvd unit in the back....should the screen inside the car still work?
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
