Need Constant 12v Power
Old Apr 11, 2009 | 10:31 PM
Trew's Avatar
Can someone recommend a constant 12v power source from the fuse box at the driver's kick panel?
I'm installing an add-a-circuit and I'd like to know which fuse you guys recommend I tap from.
The source is protected by a 7.5 amp inline fuse, so it can't be using much current. I'd hate to have to run power all the way from the battery for such a small draw.
Thanks in advance...
Old Apr 11, 2009 | 10:55 PM
csmeance's Avatar
check the power seat fuses, I believe that they have constant power. Another to check would be the window motors.
Old Apr 12, 2009 | 01:43 AM
quad150db's Avatar
Power locks or seats would be my recommendation..
Just use the 20a as normal in the bottom of your windows are only on when the ignition is on or until a door is opened... add a fuse and a 7.5 in the top and good to go..!!
Old Apr 12, 2009 | 02:28 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
I'd use the seats, not as important as the locks..
Old Apr 12, 2009 | 10:05 AM
Trew's Avatar
Thanks fruitcakes
Except AJ... He's not a fruitcake, he's just a fruit
Old Apr 12, 2009 | 03:37 PM
PhilB81's Avatar
you can't use the open slot 33? I checked with a voltmeter the other day, mine seemed always on. 31 is only on with key at acc.
Old Apr 12, 2009 | 06:22 PM
CarrieLynn's Avatar
Trew, so you ARE installing that disco ball in your car to match your leopard print seat covers and your neon rope lighting?
Nice, put up some pics when you are done
Old Apr 15, 2009 | 09:22 PM
ikm19's Avatar
Sorry for thread hijacking.. but is there any constant 12v in trunk... i dont have voltmeter or i could have check myself...
Old Apr 15, 2009 | 10:57 PM
Trew's Avatar
I used the Power Seat "slide" fuse. Can't remember what number it was. Worked just fine. I needed constant power to turn my disco ball 24/7
Actually, my DVD player has a feature that allows it to resume at the last point if you stop and then restart the car. However, it needs constant power to retain the memory.
ikm19, I doubt there is a constant 12v source in the trunk. Even if there was, I wouldn't recommend tapping into anything there. Run a new wire from the fuse box.
Old Apr 15, 2009 | 11:38 PM
ikm19's Avatar
Thanks Trew. One more question does Navtool require constant 12v or i can tap something in trunk.. i don't want to remove center console to access cigarette lighter plug. I am really bad in running wire.. i hope i can do it if i had to run wire or remove center console..
Old Apr 16, 2009 | 08:41 AM
PhilB81's Avatar
I didn't remove my center console to install the video thing, but I did run a seperate wire from the trunk all the way to the fuse box. I had to remove the plastic trim at the bottom of the door whells and the backseat. for the center console, i just squeezed the video wire under the plastic trim and unscrewed the 2 back screws so i could slightly pull it up to reach for the video cable connector.
if you want more info, just pm me, sorry for the hi-jack.
Old Apr 16, 2009 | 09:40 AM
Trew's Avatar
Do yourself a favor and run the wire. I don't recommend tapping anything from the trunk, either powered by ignition or not.
Running the wire to the accessory power outlet in the console will only take you a few hours. I would recommend running a few more wires while you're in there just in case you might need them later.
Old Apr 16, 2009 | 10:44 PM
csmeance's Avatar
it requires a switched power source, not a constant one. Running the wire is really simple, the easiest way to run it is using an add a circuit and the fuse box, then take the wire and run it under the kick panels to the trunk.
Old Apr 17, 2009 | 03:30 PM
ikm19's Avatar
thanks guys... i end up running a wire from fuse box to trunk.. i read almost 20 DIY for dom install and i took like 3 hrs. But at the end i did it myself so it felt really good..
It would have never been possible without u guys.. thanks a lot.
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
DerrickW
Nov 15, 2015 05:52 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
