nav fried... need help
Old Mar 17, 2009 | 11:03 AM
millrtyme22's Avatar
8th Gear
I had groceries in my trunk and they leaked OJ all over my Nav DVD player and thunk it shorted out! Acura is telling me I need a new Nav system for $3-$4 grand..
Has this happened to anyone and do I need a whole new system or can i just buy a new or used(where?) Nav DVD player?
How much would you pay for that used?
thank you
Old Mar 18, 2009 | 04:10 PM
csmeance's Avatar
check ebay, you can usually find units on there for around 500 dollars and swap them out youself. Be sure that if you have an 04-06, that you get the 3.xx drive (orange Disk), 2007-2008 the 4.xx drives (white disk)
OR
you can call up alpine, ask them if they can fix the drive for 150 dollars, then send it to them to have it fixed.
Old Mar 19, 2009 | 08:56 AM
Staggerwing's Avatar
'05 TL/5AT/Navi
I can't imagine that getting juice in the dvd player would require replacing the whole system. That sounds like a scam to me. I just had to have my nav screen replaced yesterday....it was $3.5K for the screen which includes all the climate controls (I bought the extended warranty, thank god). They should be able to just unplug the DVD player and replace it with a new one unless somehow the whole wiring harness for the nav system shorted...but I doubt that.
Old Mar 19, 2009 | 09:37 AM
csmeance's Avatar
the dvd drive is the brain for the system and costs around 3.5K plus 500 dollars or so labor to install...
Old Mar 23, 2009 | 04:47 AM
vinuneuro's Avatar
You can have Alpine repair it for a relatively reasonable price. Look here:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/navigation-control-unit-failure-716502/
Old Mar 29, 2009 | 10:36 AM
8th Gear
Thanks guys
Alpine said they couldn't fix it!
Is there a prt number for the drive if I have to look for one on Ebay or a Salvage yard?
Old Apr 3, 2009 | 05:14 PM
8th Gear
Can I use any Acura DVD player from say and MDX or TSX?
Like the 39540-573-A010-M1 from an MDX
Old Apr 3, 2009 | 05:30 PM
csmeance's Avatar
you would need the TL one, you can't use the other ones since the proper .bin files won't load off the dvds...
Old Apr 3, 2009 | 06:42 PM
Sal's Type S's Avatar
Ill do it for 100.00 you buy the unit and the beer.Takes less than 30Min.
Old Apr 3, 2009 | 07:24 PM
audi_to_TL's Avatar
So your gonna charge him 200 dollars per hour and make him buy the beer.
Old Apr 3, 2009 | 10:30 PM
csmeance's Avatar
it takes around 15 minutes to install, just take out the anchor hooks for the cargo net, peel the trunk liner back, and then unscrew the 4 screws and take out the harnesses.
HOWEVER
the book calls to take out the rear seats so the whole trunk liner can be taken out which means more time and more $$$ for the dealer.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
