More Bluetooth Troubles!
Old Dec 13, 2005 | 06:25 PM
fastcyc's Avatar
All of a sudden my bluetooth system (which has worked flawlessly for 10,000 miles) is screwing up. I have a Motorola V710. Whats happening is this:
I can make outgoing calls, no problem. When the audio system is on, the volume will automatically decrease during the duration of the call and everything returns to normal when the call is finished . . .
The problem is INCOMING calls. As the call comes in, the audio volume goes down, the car announces that I have an incoming call, and I hit the button on the steering wheel to answer - as soon as I do that, the stereo volume goes back up to where it was, and the car acts like it just dropped the call. HOWEVER, the person calling can not only hear me, but he or she can also hear my stereo playing. I CAN'T HEAR THEM AT ALL.
THIS ONLY HAPPENS ON INCOMING CALLS - outgoing is fine. The car is an '05 TL, auto trans, no nav. I ran diagnostic on the HFL and its says everything is fine, but obviously it is not! Anybody have this happen to them?
HELP!!!!
Old Dec 13, 2005 | 06:43 PM
rventu's Avatar
I have the same issue. Do you have your phone set on a ringer? I found that it must be on vibrate or silent otherwise what you described happens.
Old Dec 13, 2005 | 06:45 PM
fastcyc's Avatar
I have had the phone on "vibe then ring" for quite a while with no problems at all. I am going to try it on vibrate and then on silent and let you know . . .
Old Dec 13, 2005 | 06:59 PM
rventu's Avatar
Have you updated or changed the ringer lately while it was on vibe then ring? I also have a V710 by the way and had the same issue both in my 05 and now in my 06 TL.
Old Dec 13, 2005 | 07:11 PM
fastcyc's Avatar
Okay, thanks for the replies . . .
I took two cell phones into the car to check it out, and here is what happened:
First, I changed the ring style to "silent". The phone acted normally, and took the incoming calls normally.
I then changed it to "vibrate" - everything still fine.
I then changed it to "loud" - everything fine.
"soft" - everything fine.
Then, I went back to "vibe then ring" (the original setting) and, EVERYTHINGS FINE.
WHAT THE HECK IS GOING ON WITH THIS POS MOTOROLA!!
Again guys, thanks for the input. Thought the car was a piece of crap when the real piece of crap is the phone . . .
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
SUPRMN84
Oct 7, 2015 09:46 PM
