MAKING dvd-a????????
Old Nov 16, 2006 | 06:12 PM
Armydog14's Avatar
i've read most of these threads in regards to making a dvd-a but i still can't do it. i got nero 7 and i can't make a dvd-a with that software. anyone can offer me some assistance? i have a 2006 which plays dvd-a so i'm trying to make a dvd that holds allot of songs.
Old Nov 16, 2006 | 06:25 PM
sixsixfour's Avatar
look up adobeman. he has a nice GUI you can install.
Old Nov 16, 2006 | 07:00 PM
Thorin78's Avatar
Previous Owner
Here you go
https://acurazine.com/forums/showthread.php?t=135210
it's in the audio bluetooth section
Old Nov 17, 2006 | 12:29 PM
Armydog14's Avatar
ok i dl adobemans gui and made an iso file. then i took the iso file and burned it using nero 7(dvd data option). popped it in my tl and........ no dice! HELP!
Old Nov 17, 2006 | 01:20 PM
Hawhyen51's Avatar
Which DVD media did you use? The success rate is greater using DVD-R vs +R. You might also try burning at a slower speed.
Old Nov 17, 2006 | 02:06 PM
AdamNJ's Avatar
Make MyTL Great Again
Armydog14:
You are burning the image incorrectly. When you open Nero and the wizard pops up close it out. On one of the menus in the middle of the menu bar, there is an option for burn image. Choose that. It will pop open an 'open file' window. Choose the .iso file that Adobeman's software made. After you do that, it opens up the burning window...you should know what to do then.
Old Nov 17, 2006 | 04:08 PM
vinh077's Avatar
Try burning at the speed of that media. I made 3 so far and only 1 worked. first was compusa DVD-R media burned at 2x - didn't work, next verbatim DVD-R at 2.4x - didn't work
next verbatim DVD-R at 8x and it worked.
Old Nov 18, 2006 | 07:12 AM
Adobeman's Avatar
The DVD-A Script Guy
If #2 and #3 (both verbatim) are the same exact media then you have some flaky hardware and or firmware somewhere. Otherwise, if all three were different media then that's your issue.
Old Nov 29, 2006 | 09:56 PM
shanezam203's Avatar
Adobeman, thank you for the program. I am converting my MP3's now.
Once that is done I will try burning the image in Nero. I have DVD +R is that ok, I see on here DVD -R are suggested.
Should I get -R's for the TL?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
The Machine
Sep 24, 2018 08:27 PM
pistacio
Sep 26, 2015 09:45 AM
