Looking to install some subs in my TL-S
Old Apr 29, 2013 | 03:42 PM
RichieRich813's Avatar
Hey guys so I wanna install a couple subs in my trunk and I was trying to figure out where I can install and connect my remote wire to instead of takin my whole screen apart and connectin it thru the radio. I hope it is possable. Thanks
Old Apr 29, 2013 | 03:45 PM
Mrtastygoody's Avatar
Level: Noob
Try the Electronics section man
Old Apr 29, 2013 | 04:11 PM
Anyone connect the remote wire to the navi cd player in the back??
Old Apr 29, 2013 | 04:19 PM
anx1300c's Avatar
Old May 5, 2013 | 03:04 PM
ok I figured that out now I've been searching everywhere to figure out how to connect my RCA's. All I've been able to find is people hooking up amps to their door speakers which involves taking out the stock amp up front which im not trying to do. I have a device where I can splice the rear speaker wires and its hooked up to a box with the 2 RCA ends. I haven't seen anybody talk about that so im not sure if I can do it because of the stock amp up front. I want to keep anything else stock up front. please let me know if this is possible. THANKS!
Old May 5, 2013 | 07:30 PM
niebur3's Avatar
Use the line out converter you have, connect it to the wires going to the sub in the package shelf and it should work fine. If you do it that way, you can still control the volume of the sub using the Head Unit.
Old May 7, 2013 | 04:46 PM
ok awesome thanks. so the neg from the left and right rca converter I can just wire together and hook it up to the amp neg wire then do the same for the pos???
Old May 8, 2013 | 09:01 AM
350's Avatar
350
My first ricer
Use a line out converter or high level inputs if the amp has it, just cut the wire's going to the stock sub. Ground to the bolt for the fuel pump on the floor, run the power wire from battery, through the grommet in the middle of the firewall then back to the trunk. Also you need to add a remote wire, get an add a fuse and an extra fuse, put it to an ignition on fuse. I think 07-08's need to remove the active noise cancellation, not sure on that since I have an 06, but it was one of the simpler installs I've had to do adding just a sub amp.
Old May 8, 2013 | 09:27 AM
Mr3lite's Avatar
You do have to remove anc from the rear dome lights...once you pop them off you have to unplug the green clip. Otherwise you will hear a lot of "thumping" noise and it wont be the subs. Also you may want to just disconnect the rear sub but splice you aftermarkets to the wires so you can use the head unit to control it all.
I did this like 3 years ago, didnt touch the navi unit
Old May 8, 2013 | 02:09 PM
TLDude876's Avatar
Chapter Leader (Houston)
What my buddy and I did on the wknd, except we put the ground by one of the seats screws.
akbears15
15
Nov 5, 2015 07:06 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
alan_rich
Sep 7, 2015 11:08 PM
