Left tail light keeps burning out
Old Mar 17, 2007 | 10:19 AM
boe_d's Avatar
My left tail light on my 2001 acura TL keeps burning out - the replacement I put 2 weeks ago is burned out already. the brake light still works.
Is there something I should check?
Old Mar 17, 2007 | 11:07 AM
Desert_TL's Avatar
Interesting. I would make sure that the base or the mount for the light is fully secured and doesn't wobble or wiggle around if you try to move it. If the mount shakes or vibrates a lot while you're driving, that could significantly shorten the lifespan of an incandescent bulb.
HiTEC's Avatar
You're on the wrong forums. This forum is for the 3G TL (2004+).... our taillights are LED's and not bulbs like in your 2001.
Old Mar 17, 2007 | 11:31 AM
01tl4tl's Avatar
Check for clean and tight ground wires whenever you have wierd electrical probs
Old Mar 17, 2007 | 01:27 PM
HiTEC's Avatar
You think taillight bulbs are like headlight bulbs where you don't want to get your skin oils on the glass? I know this could cause decreased life on headlight bulbs???
Old Mar 17, 2007 | 01:43 PM
lusid's Avatar
FTW
Either way, I wouldn't want to degrade the life by touching it with our fingers.
Old Mar 19, 2007 | 02:36 AM
datmrman's Avatar
Since I cannot move threads across forums, feel free to repost this in Second Generation TL (1999-2003).
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
