iSimple & Video
Old Oct 24, 2010 | 08:39 PM
woow14623's Avatar
iSimple & Video
Hi All,
I want to integrate my Iphone to listen to music and also video. I am read many threads but I see easiest audio integration is Isimple as I see. How could I get the video working? what are my options when used with Isimple.....please provide me some ideas I really need help.
thanks in advance
Old Oct 24, 2010 | 10:06 PM
jptl04's Avatar
Bone stock tl-s
apple composite video cable is your ticket. its what i used here my video
http://www.youtube.com/watch?v=QtN2rNk952U
Old Oct 24, 2010 | 10:33 PM
woow14623's Avatar
Do you have any installation instructions? I would appreciate it extremely if you could provide me some help.
Old Oct 25, 2010 | 03:03 PM
robhale00's Avatar
5th Gear
That is frickin' awesome!
Old Oct 26, 2010 | 07:05 AM
woow14623's Avatar
could someone pls help. I only thought isimple only support audio. How having apple composite cable + isimple support both video + audio. Could someone please let me know what all I need ?
Old Oct 27, 2010 | 07:50 AM
oneway's Avatar
Old Oct 27, 2010 | 07:57 AM
SharksBreath's Avatar
BANNED
Originally Posted by oneway
+1
to get video on the navi you'll need the following:
1. navi converter (dom's nav2go) allows you to connect two video sources when powered up, its hooked up to the dvd rom drive in the trunk. it also a switch to power it.
2. the apple composite video cable. one side plugs in to the bottom dock area of the ipod and the other has audio L and audio R plus a Video and a usb power source to enable to charge the ipod/iphone.
3. for the audio you could get the P.I.E. X3 unit that connects to the back of the radio allowing you to connect up to 3 audio devices with a selector switch.
another way to get audio is to go through the aux jack in the center console. you'll need to get a two to one audio cable spiltter. a cable that has two rca R/L plugs that go to one male plug/connector that will connect into that jack in the armrest.
*google the hot items, make a list, empty your wallet*
Old Oct 27, 2010 | 10:11 AM
oneway's Avatar
another way to get audio is to go through the aux jack in the center console. you'll need to get a two to one audio cable splitter. a cable that has two rca R/L plugs that go to one male plug/connector that will connect into that jack in the armrest.
I have a dumb question I am assuming that you also need the I simple, but what turns the video on for the display and where is the audio source coming from for the video. I know that the I simple comes through the SAT, but I don't understand how the video and audio source are directed to the navi at the same time. I'm sorry for dumb question i don't like asking them especially when it is probably simple.
Thanks Anthony
Old Oct 27, 2010 | 12:05 PM
24no7's Avatar
UA6 SSM TL
i got the navitool in my car which i think is simillar to the navi2go, im using a dvd unit and a back-up camera so i can't connect another source. how could i made this work wihtouth having to buy the nav2go??
Old Oct 27, 2010 | 12:21 PM
jptl04's Avatar
Bone stock tl-s
Thanks Anthony
the isimple is for ipod integration into your existing oem radio. it alows you to have full control of track,playlist,artist,songs from your ipod/iphone using the oem deck and steering wheel controls. it has no effect when playing videos, because it does not support the video function.
the composite cable has the audio out rca plugs and video out connector as well. its a completely different cable the rcas audio out cables connect to the P.I.E. X3 (google it for more info) which is connected to the oem radio AUX. the video out connects to the navi converter box aka (nav2go) when powered up it sends the video signal thats connected to it to the navigation screen. to return back to the map screen just flip the toggle switch thats provided with the nav2go.
so connect your iphone to the composite cable/dock select video. flip the toggle to power the nav2go for video and select AUX on the deck for sound. check the video
Old Oct 27, 2010 | 02:07 PM
woow14623's Avatar
Given the slow response to this thread for days.....I researched like crazy.....
This is what I am going to use......
http://www.autotoys.com/x/product.php?productid=9231
which supports video & audio.
reasons.
1. Do not need many modules....one remote changes the modes.
4. Do not need switches or different connection for audio and video
2. Cost 212 + expenses for the iphone composite
3. Can fix in the trunk.
autosys have bad name in customer service.....but I e-mailed them yesterday asking for information and they replied me within mins. Also in the site they say they have new improved version.
any comments? suggestions?
Old Oct 27, 2010 | 04:07 PM
oneway's Avatar
Thanks a lot it's crystal now.
Old Oct 27, 2010 | 07:06 PM
jptl04's Avatar
Bone stock tl-s
reasons.
research some more!!!
you still need a aux sound adapter, an audio out source. im assuming this unit connects to the dvd drive in the trunk. you can't get sound through the navi unit. only video. thats why you still need a blitzsafe/p.i.e.x3 for audio.
i havent seen anyone use that particular unit. but it seems nice for the fact that it charges the iphone with a usb port. and has a wireless remote to select the video.
that being said. why? its only one switch. you can mount it anywhere. its a tiny toggle switch. just flip it on. no need to have a remote for that. the composite cable is not that long. it has the usb cable attached. you'll have to get a usb cable extender to get it into the trunk if you want to use that port.
get the tried and tested unit Nav2Go.
Old Oct 27, 2010 | 07:33 PM
24no7's Avatar
UA6 SSM TL
what about me!!!! no body would reply hajajajaja
Old Oct 27, 2010 | 08:44 PM
woow14623's Avatar
Thanks Jptl......here it is in action......it has been used by one user here...
http://www.youtube.com/watch?v=6mWhlkPtmlQ
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/new-navi-video-interface-w-extras-audio-i-p-usb-charging-ipod-ctrl-remote-729815/
Old Oct 27, 2010 | 09:48 PM
jptl04's Avatar
Bone stock tl-s
https://acurazine.com/forums/showthread.php?t=729815
i guess you could be #2 if you only have/want one audio source going in.
pros
audio + video in one
usb charger
wireless remote
cons
confusing remote (wayy too many buttons)
loss of nav traffic
must be connected at the deck or radio, (take apart the entire radio stack) for usb charge function
autotoyz customer service blows
taken from the thread, member who installed it.
Originally Posted by dipkat
Too painful experience. Paypal closed my claim. Did not receive any money back from AutoToys. Bad experience.
Also, after 3 months of use, I do not like the sue of a remote. The system resets to the video interface to the navi every time you shut the car. You have to activate the video input every time you want it on. I missing the convenience of a manual switch. Plus, every time there is a law enforcement vehicle around, I have to scramble to reach out and hunt for the remote. Such a pain when you need to change the video source in a rush. The manual / push-button switch is more functional in my opinion, compared to the remote. Go with one of the other video setups if you can and save yourself lots of headaches.
remote for one video and one audio source along with factory screen/nav
my switch set up for two video sources dvd/iphone/ and two audio sources dvd/ipod/iphone/ along with factory screen /nav (i can select video or audio for any device with these two switches and one button
Old Oct 27, 2010 | 10:39 PM
24no7's Avatar
UA6 SSM TL
so u are saying ur installation was much easier than his??
Old Dec 23, 2010 | 09:34 PM
mrlal8's Avatar
anyone have pics of how the i simple looks on a non navi tl?
Old Nov 26, 2011 | 10:41 PM
07TLTypeS420's Avatar
3.5L...enough said
If we ever end up at one of the meets I'll show you
Old Nov 27, 2011 | 12:27 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Haha... he's not referring to the installation... he's referring to the items used to achieve the integration. JP is psycho (I mean this in a good way bro) when it comes to customizing his installs and aims to achieve that wow factor with his installs .. which he does.
If you guys want to do this the most simple and maybe even cost effective way get do it the same way way me and JP did it.... PIE X3 + Dom Nav Converter or Navtool (same crap) + Apple AV cable + 15' Composite Video Cable. I'm still skeptical on this remote thing... though its cool... I feel like its too cumbersome and not simple to operate... plus that stuck on eye thing to me looks like an eye sore. I don't even like the 2 inches of wire that is showing in my proclip setup.
As far as docking options this is all personal preference. I love my pro-clip dock the same as I did the first day I had it which is over 2 years ago. Amazingly convenient! I do admire JP's custom dock but I feel that his positioning at the cup holder would've made it difficult for me to operate my phone on the fly when I get messages or if I have to grab my phone really quickly or change tracks and browse songs while in motion. I think it would break my neck. So I chose practicality for my application. Like I said mounting/docking options are all personal choices but the main point here is using the PIE X3 and NavTool.
Here's a video and thread I created after I did it at the end of 2008 I'm going to add one more feature to this which will make it even more functional, but limited on time so will do shortly and update.
https://acurazine.com/forums/showthr...=iphone+3gs%2A
http://youtu.be/cZ8-NrECLvQ
http://youtu.be/wu1O_ZI0ZQU
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
