iSimple Cable Problem
Old Feb 11, 2013 | 08:53 PM
dredreezy's Avatar
I'm having sound problem with my iPhone cable. Recently the sound has been playing on the speakers of the right side of my car. Kind of shorting out...I have to jiggle the cable to get the sound throughout my car.
I have checked my CD Changer and Radio to see if it was my speakers and they are fine. So I know its my iSimple... However, Is it my cable or my iSimple hardware?? I am willing to order a replacement cable for $20. But I dont know if that will work or pay for another system.
I have an 05 Navi TL by the way.
Old Feb 12, 2013 | 12:50 PM
pohljm's Avatar
Perhaps jiggle cable until working then secure cable to isimple device. Use contact cleaner at the cable connection. Do you have the same issue if using the 3.5 jack on aux? Or just the idevice cable?
Old Feb 12, 2013 | 01:58 PM
alexb92's Avatar
It's the cable - I've noticed this happens if it is at a certain angle. Doesn't bother me that much yet.
Old Feb 12, 2013 | 02:55 PM
dredreezy's Avatar
I jiggle the cable, it used to work after doing that now it doesnt. It's just the cable.
Old Feb 13, 2013 | 10:04 AM
Butler230's Avatar
Check the pins on the cable where it attaches to the isimple unit. I had the same problem and found that one of the pins at the end of the cable had broken off inside the isimple unit.
When I wiggled the unit around I could get it to work ocassionally because it would line up just right. The broken pin eventually went too far into the unit and it would only work on the right side speakers.
Old Feb 13, 2013 | 11:10 PM
dredreezy's Avatar
I tired, no success...so basically I need to replace the cable.
Old Feb 14, 2013 | 10:45 AM
Pghpizzaman's Avatar
2004 TL SSM w/NAVI
is your connection good on your ipod? i have that problem with my ipod cause it's old, but my wife's iphone works fine. just a thought...
Old Feb 14, 2013 | 11:45 AM
denalijb's Avatar
Do you have the newer think cable?
Old Feb 14, 2013 | 12:18 PM
dredreezy's Avatar
I have my iOS updated on my iPhone. I tried using my Pod Classic that I dont even use anymore and it is doing the same thing.
dredreezy's Avatar
???? Newer think cable??
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
