An ipod option that you might not have considered
I hope this isn't old news to everyone, but I haven't seen a thread on it yet.
I would love to have ipod integration, but I'm not willing to pay the price unless it did everything I want it to do (including not disable XM, and good, intuitive, effective controls of the ipod through the factory unit controls). But I do care very much about sound quality and the fact that using the ipod from the headphone jack through the aux input makes you raise the volume.
Therefore, I use a dock connector cable. It plugs in the dock connector of the ipod to the aux jack of the factory unit. I still control the ipod with the ipod itself, and this means I can't be charging the unit while it's plugged in this way. But the advantages are significant:
1. Sound quality is identical to an integration unit. None of the increased signal to noise ratio that you get through the headphone jack. Sound is phenomenal.
2. The audio from the ipod is delivered to the factory unit at "line level", meaning I don't have to do anything to the volume on the ipod. The volume is completely controlled through the factory unit, and my ipod's headphones volume doesn't have to be adjusted.
An example of this kind of cable can be found here:
Dock Connector Cable
As I said, this may be old news, or you may require car charging. But for those of us who care most about sound quality, this gives a nice alternative to integrated units for about $15.
No, read the original post again (I must not have explained it as thoroughly as I thought.)
When you use the typical aux cable, you are coming out of the headphone jack. This signal is not as clean as coming out of the dock. Also, you have to turn up the volume to get it to a high enough level to play through the stereo.
Using the dock connector cable sounds better and sends a full "line level" signal to the stereo, so you don't have to turn up the volume on the ipod.
The better sound is not as dramatic as going from a tape adaptor to an aux cable, but it is real and noticable. Using the dock cable gives you as clean a signal as the integrated units.
Tough crowd.
I'm not pimping Amazon, I'm suggesting something that a lot of people don't know about. If you can buy this in a mall kiosk for 10 bucks, even better.
I've seen the dock connector cable and no, you can't buy it at the mall. Heck, I've checked radioshack, circuitcity, bestbuy, etc.
It's definitely better audio quality because it's line out.
this is what i use it also charges your ipod and comes with an aux cable.it sounds great http://www.griffintechnology.com/products/autopilot#
That's a convenient device, but it is still hampered by having to use the headphone jack for the audio. Your signal to noise ratio is not as desirable as a dock output, and you still have that issue with volume control.
For many people, this is simply not an issue and they are as happy as they can be with their solution. I am just letting people know that they can get a better, cleaner signal by using the dock.
As to the 05 and earlier, the cable I mention still needs an aux port. You could look for a dock connector to rca cable (I know they make it), and then you would need to get behind the dash and look at hooking it up to your unit directly, if that's possible. Then, of course, you're into more effort, and it may be worth it for you to just look at the integrated solutions at that point (unless you don't mind getting behind the dash yourself.)
I didn't read closely enough, and just assumed what I wrote. My apologies. That is a very interesting device, and it not only gets you all the advantages of the cable I mentioned, it also allows you to charge.
Nice find.
Nice find.
I looked at that device, however there are cheaper alternatives if you don't won't the control, which provides an iPod Dock connector to both USB (for charging via a USB car adaptor) and a .125" stereo jack for the AUX. This allows a single cable to the iPod that give line level audio and charging.
http://shop1.outpost.com/product/513...H:MAIN_RSLT_PG
It is for a Kenwood, but still works in the TL type S '08 just fine. The only thing I would change is a mod in the dock connector to allow the iPod to switch off when power is removed from the USB port. (Turn off ignition)
In addition there is a video version of this as well but have not tried this one. http://shop1.outpost.com/product/525...H:MAIN_RSLT_PG
Just checked out the Griffin link and found another option from them - if you don't want the controls and you want the iPod "mounted":
http://www.griffintechnology.com/products/tuneflexaux
I am so glad to have stumnbled on this thread. I'm driving my 06 TL 600 miles to trade it in on an 07 TL-S - that of course has the aux input. I've been playing the iPod through the tape player for 18 months and I HATE the volume adjustment!
I drove several cars while trying to decide how to replace my 06, including a BMW 335i (too expensive, but one HELL of a car) and 2 Audi S4's. Seems like everyone else has figured out how important the iPod interface is to the consumer - both of theirs seemed to work great. Hard to believe that these posts are still popping up on here; I've seen several that are 4 years old or more. I love Honda, but come on already!
Still hoping that the dealer will be able to retrofit an adapter that gives full functionality via the NAV screen, but I'm glad I didn't hold my breath.
Originally Posted by acura911
ok your setup is not going to work;and on mine you still have one cable running to your ipod.read the post and look at the web site a little better.ok
Reading about the product on a different site, it looks like it is set up to perform control functions (via a Kenwood receiver) as well as supply power via the USB connector. Could be that it will still supply power, but would obviously not have control capability. At $20, it's less than half the price of the Griffin product.
I don't think that last product I posted (see previous) is feasible for the TL due to the location of the aux input - unless you want to "mount" the iPod in the console... Kind of defeats the purpose.
@ChemicalLew - Yes I have it working just fine (TL type S 2008) and there is only the single dock connector on the iPod. No headphone connection, it uses the line out on the base of my 160GB Classic. You are also correct, that with the Kenwood head unit it would also provide control, in my case it just provides the power using a USB car adaptor.
I looked at the Griffin and I could have used the front tray power socket and run the audio cable from that into the console for the Aux in, but decided for now, $20 was good enough until I decide to go for a better integration with steering wheel control.
All I was looking for was power and audio with a single dock connector.
Here's an even cheaper option for the same cable:
http://www.amazon.com/gp/product/B000UMC394
You can't beat that deal. I just got my order delivered (I bought 3 - one for home, one for car, one for work...I started using a headphone amp for home and work).
It looks very well made, not cheap at all. Cable is rather thick, and connector solid with releases on the sides.
The DVD-A Script Guy
It's true. Rio Rebel is dead on. The dock connector is far better than using the headphone out. I've verified this many times in the house using both the headphone out and the dock on different audio systems. The fixed volume level is also much better in the car also since you can't accidentally change the volume while using the thumb wheel. There are many EE reasons for it but that's another topic.
That said, unfortunately, "better" out of the dock connector still isn't "great sound". Stream a 320k mp3 through any decent media renderer and compare it to the same mp3 from the dock-out of an iPod and you'll hear what I mean. Even my POS Linksys Media-Link destroys an iPod. But since the iPod excels in so many other areas it's worth the trade off.
Looking for new mods
I have this set up for now.....
and a short aux cable right into my aux on my 07.
The charger has an amplifier...lthoug it sounds a bit better than the headphone jack........the sound is still a bit muffled.....very loud...but i will still recommend getting somethign like dice...changing the music from the ipod is a driving hazard
Trucki!!
Originally Posted by PSURob12
I may consider one of these, as the USA Spec and other similiar setups look like too much for me to handle on my own. Plus I don't want to void any warranties.
Oh, and x2 on what Lembowski said about warranties; you're not doing anything to void a warranty.
Originally Posted by blkaspec
nope, no aux port. 07+ only
Originally Posted by jim in atl
Dangit!!!! Just purchased an '05. I guess I will have to stick with the radio tuner ipod cable. Isn't there some way to bust into the thing? or find a jack around back?
TLguy42
09-26-2015 11:27 AM
09-25-2015 06:14 PM
4drviper
09-23-2015 09:00 PM
