Installion Of PIE X3
Old Jul 27, 2006 | 12:41 AM
icanfly's Avatar
Do you think the installation of the PIE X3 will be difficult to do? The only thing i think i will have trouble with is powering the device. I dont really get how to do that. How much do you think a reputable shop should charge me for the installation of the PIE X3? I'm in southern california.
Old Jul 27, 2006 | 01:12 AM
datmrman's Avatar
It's not difficult. You might need to take apart the car to get to the plug behind the head unit and to mount the brain and/or switch. Other than that, nothing too difficult. Mini add-a-circuit or just tap into the front power outlet to power it.
Where are your located in SoCal?
Here is my installation thread to help you get some ideas.
IMO, do some research and its an easy DIY. There are many threads with pictures and helpful info on here.
Old Jul 27, 2006 | 09:47 AM
luniz97's Avatar
just don't buy the usa spec one...i hate it
Old Jul 27, 2006 | 11:21 AM
lembowski's Avatar
Trucki!!
wow, tell us how you really feel. Do you have a reason?
I could say don't buy the PIE the USAspec is better
Old Jul 27, 2006 | 11:42 AM
datmrman's Avatar
luniz97 had issues with getting his USA Spec to work. He's just a little bitter.
The USA Spec works well for many and his case is one of those instances that you get with every module.
Each product has advantages over the other. Its just personal preference... like many things.
Old Jul 27, 2006 | 06:07 PM
icanfly's Avatar
How much do you think a shop should charge me for the installation of this? I really dont feel comfortable tapping in to get power for the PIE X3. If anyone knows any good shops in the Fullerton area it would be helpful.
Old Jul 27, 2006 | 07:26 PM
Laxplaya11385's Avatar
it's really not worth the money to have someone install it. All you need is to make sure you have the power wire, to ground wire, and squeeze connectors from your local electronics store (or radio shack). Also, (I don't know if you HAVE to, but i do it anyways), unplug the battery.
Old Jul 28, 2006 | 12:40 AM
datmrman's Avatar
Not worth paying someone to do the install. Read up on how members have installed theirs and just take it slow.
The mini add-a-circuit route will not require you to tap/splice any factory wires. I didn't unplug the battery during my install.
With time and patience, you can do it!
Old Jul 31, 2006 | 06:31 PM
rahulkumar's Avatar
Haha, I'm glad I kept reading, I was about to make my own post about this, but datmrman, where does the mini-add-a-circuit go to and how does it work?
Old Jul 31, 2006 | 08:01 PM
datmrman's Avatar
You can use fuse slot #32 in the fuse box in the driver's side well.
The mini add-a-circuit looks like this:
After hunting for it for a while, I found it at AutoZone.
gmahn
Jul 28, 2006 05:50 PM
einsatz
Oct 6, 2005 10:40 PM
