Installing DVD help.
I bought a dvd player and i would like to hook it up to my navi
i hooked up the dom no the video is good ...the only problem i have is the audio.. i was going to t-tap the wires with the stock radio to the dvd player....is that how you get the audio??
thanks
thanks
The Dom's unit doesn't provide audio interface. You will need an additional device for that. The iSimple seems to be the most popular choice around here; it allows direct control of an iPod as well as an AUX input for other devices, like a DVD player. In order for you to get sound from your DVD player, you will need one of these units.
Of course, I said all of this assuming you have an 04-06 TL. The 07-08 models have an AUX input in the center console which you could just hook into.
yea I understand now thanks![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
i have both and now i know how to wire it..
what about the power? how am i going to get the power?
do i t-tap the cig lighter or the factory radio?
ya i got my dom light install and isimple...
im talkin about the "dvd player" do i tapped into the factory radio to get power?(red and green wire)
Someone may correct me, but I would leave well enough alone with the factory radio. It's too expensive a piece of equipment for me to tempt fate by possibly diminishing the amount of power it gets by adding something else to its circuit.
Where to get power for your DVD player all depends on where you want to put it. If it were me, I would probably use an add-a-fuse in the fuse box and run a line to the DVD player (particularly if you are putting it in the center console) as that won't be too long a run. But it's all a matter of preference. When I added my WDTV (hard drive based media player), I used an add-a-fuse.
i want to put the dvd player etheir under the radio or in the back cup holders wherever it fits... i check the "diy" and it doesnt explain how to wire it (power)
add a fuse...to what fuse?
BoricuaTL
04-08-2016 01:08 PM
Pegon95
09-15-2015 01:54 PM
yahelou
09-06-2015 09:12 PM
