installed sub/amp and now sound only comes on when the engine is on... help!
Old Mar 13, 2005 | 01:33 PM
MugenR's Avatar
300whp 237wtrq
I installed the Sub and amp, but now that i've installed it... whenever my car is in the on position (position II on the ignition) the radio/cd plays, but no sound comes out from any of the speakers. i have to turn on the car and have the engine running to hear the sound.
does anyone know what's going on?
Old Mar 13, 2005 | 01:38 PM
docfnky's Avatar
did you amp your speakers as well? in the case that you did, check the remote turn on wire
Old Mar 13, 2005 | 01:49 PM
MugenR's Avatar
300whp 237wtrq
no... i just amped the sub
Old Mar 13, 2005 | 01:52 PM
docfnky's Avatar
it wasn;t like this before right? haven't picked up my TL yet so i don't know how they laid out the system....but if u didn't touch any of the speakers wires....check the wiring for the factory amp anyway
Old Mar 13, 2005 | 02:17 PM
MugenR's Avatar
300whp 237wtrq
yea... it wasn't like that before.... hmm
Old Mar 13, 2005 | 02:42 PM
docfnky's Avatar
check the fuses in the car...like all of them both inside and under the hood
Old Mar 13, 2005 | 07:36 PM
MugenR's Avatar
300whp 237wtrq
all the fuses are ok.
Old Mar 13, 2005 | 09:14 PM
docfnky's Avatar
hmmm....its so hard to not have the car in front of me to check....my car won't get here until the 15th of april...let me know if you fix the prob...i'll continue to try and think of a solution
Old Mar 14, 2005 | 03:03 PM
MugenR's Avatar
300whp 237wtrq
I've figured out the problem.... I hooked up the remote wire to the Red/Yellow wire to the amp. (this is the remote turn on lead for the stock amp. it wasn't giving enough juice to signal the stock amp and the sub amp at the same time with just the battery. with the car on the "on" position it only gave 5 volts. I moved the remote wire to the Yellow wire that goes to the stock amp (it's the ignition wire).. this was giving off 12 volts i needed. works now.
but still getting a annoying rattle from the stock sub area... gotta do that fix... i'm too lazy though.. hahaha
thanks!
Old Mar 14, 2005 | 04:27 PM
docfnky's Avatar
awesome...thanks for the heads up i'll keep that in mind when i do my install. the same thing kinda happened to me when i did my friend's corolla. I hooked it up to the fuel pump and his check engine light kept on going on and off...figured it out and move the remote wire to the cig lighter and it's fine now.
Old Mar 15, 2005 | 01:21 AM
sparkz's Avatar
thanks!
That;s odd, I tapped mines from the same wire (red/yellow) and dont have any problems with that. The only thing I get is just a light amp/speaker pop when I turn off the card. Do you get that with yours?
Old Mar 15, 2005 | 12:08 PM
MugenR's Avatar
300whp 237wtrq
no... never got any speaker pop
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
