Installed new factory radio still no nav screen??
2004 TL SSM w/NAVI
i just purchased my tl last week and it had a pioneer double din where the stock radio was. i hated how it looked and bought a used stock radio to install. Had an audio shop install it and the radio works fine but still no display on nav screen. it is getting power you can tell because it turns grey when the car is on but nothing displays. all factory harness's were intact so i dont think wiring is the issue. is there something i am missing or is my screen shot also? i really dont want to buy a screen if it is not the problem. i searched but couldn't find an anwser any help will be appreciated...
2004 TL SSM w/NAVI
nobody? i seen all the threads about sending the nav unit to alpine for repair, but i wasnt sure if that is the problem. should i have no display at all? no error messages?
Did you get the correct stock radio? You have to use one out of a navi car or the navi won't work.
2004 TL SSM w/NAVI
yea radio is the right one came out of an 04 w/navi. same as mine. radio plugged in and worked fine just no screen. looked like when you turn on your tv without turning on your cable box. i put the double din back in til i figure it out. is there a certain sequence to get it on? i didnt disconnect the battery when i did it so i was gonna try to put it back in and disconnect the battery then see if the dvd drive in the trunk is making any noise.
7th Gear
The Navi systems have anti-theft codes. That may be what is causing this problem. You need to get the anti-theft codes for the radio and Navi from the previous owner and enter them into the system. They come on a card and are usually in with the Acura owner manuals in the glove box.
6th Gear
T-Town TL-S
Yes you need a code, but the screen has to work to put in the Navi code.
The radio code is input through the radio preset buttons, the Navi code is entered via the touchscreen.
2004 TL SSM w/NAVI
yea i have the radio code but no navi code. and the screen would need to work to put it in. i dont have an owners manual so i guess im going back to the dealer for that code also.
The radio is no different between navi and non-navi. I've done the conversion and the only difference is some pins are used on the navi that aren't on the non-navi. One being audio for the navigation.
But I have to ask a stupid question. Is the navi unit in the trunk there along with the subdisplay? When you say you popped the radio in, were all the connections on the back of the display used? Not trying to offend you or anything and you do say the harness was intact but you don't say if it was previously a navi based TL. If they replaced it with an aftermarket unit, many times they are non-navi.
HalfAnP (03-29-2012)
2004 TL SSM w/NAVI
2004 TL SSM w/NAVI
haven't had any time to get the dvd unit out to ship to alpine but hopefully this week because the car is going to get the a-spec front lip painted, and a front bumper repaint cant wait
TL-S
Long shot, but I blew the fuse and my screen went out so that could be your problem too.
Its possible they touched two wires together. I wanted to extend some wires and I cut them both together like a dumbass and the pliers I was using made the wires touch.
Check the fuse box at the driver's footwell area. Its the fuse for the front acc. power. (It's for the outlet below the stereo in the bottom pocket) For some reason the navi screen is on that fuse as well (I know because I blew that fuse and my navi screen went out, and I nearly pissed my pants while simultaneously crying).
Its the third fuse from the back, bottom row if i'm remembering correctly. Read the fusebox door and it'll say something like that.
When mine blue the screen wouldn't light up.....I think. I don't remmeber 100% though.
You can tell if your navi unit is working by pressing the buttons (settings, cancel, menu, etc.) It should beep each time you press a button indicating its changed pages/menus. Mine was still doing that when the fuse blew.
2004 TL SSM w/NAVI
well i just got the great news from alpine that my navi unit is non repairable due to a soft drink spill. WTF?? So the one below is the only one i found. Is this the correct one? Do i need to match any numbers on mine or any 04 tl unit will work? Is this a good price? what price range should they be in? thanks for the help, i'm so pissed right now it's unreal!!!
http://www.ebay.com/itm/Trunk-naviga...2f4bc9&vxp=mtr
Soul_Deamon
11-13-2018 04:44 PM
handsom-hustla
11-13-2015 05:04 PM
andysinnh
09-05-2015 11:38 PM
asahrts
09-04-2015 05:55 PM
