infinity 63.7's installed
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Just installed a pair of infinity 63.7i's in place of the stock back speakers. These are 3-way 6.5in speakers and are a huge improvement over stock. I upgraded my sub and the bass completely drowned out the stock speakers back there. Now I can actually hear the treble coming from the back, it sounds great.
The install was easy...remove rear deck plug and play. There are four holes for screws on the 63.7's and only three on the stock speakers so I ended using silicon to hold them in place along with one screw on each. No rattling at all.
The best part is how inexpensive these speakers are. I bought mine from:
http://www.techronics.com/index.cfm?...2781&aff=45847
I had to call them to place the order bc website wasnt working. They even came with a $10 off coupon...may buy another set for the front! These are great speakers for the price.
mainly Vibration. Silicone won't stop the speaker from vibrating because it's flexible, which could cause the speaker to eventually come loose. Additionally, it's just not good practice to install speakers in such a manner. they should be bolted down. I had to dremel my rear deck and install threaded clips just to get my speakers to fit on the deck.
King of NYC
Wow good price on those! I paid around $95 for mine about 1 year ago. I also have 1 screw missing but absolutely no issues. I did all 4 speakers. I am not running an additional amp on it an it is pretty good. A LOT more treble than before. Could use a lil more midrange.
I haven't done the front tweets or center yet. I have put in 2 B-pillar tweets and 2 Infinity 12" subs in a Q-logic bandpass powered by a RockFos 1000 Watt amp. Sounds absolutely crazy! I play videos through my DVD player and rear headrests, lol. Everyone thinks I have a wacko $5k system but I really haven't spent that much, I spent smart.
I upgraded my center and tweets up front w/infinity, you should do that for sure. Overall for what I've spent I couldn't be happier. Great sound on a budget.
King of NYC
The B-pillar tweetscould not be mounted flush or any hole drilling above the seatbelts because there is a track mechanism that allows the seatbelt level to be adjusted. This was OK anyways because the way I installed them actually came out better because I didn't drill any holes and do any permanent damage.
I actually ran the wire up to the top of the B-pillar panel and tucked the wire out of the edge of the panel. I just double side taped the tweeter in such a way you can't see the wire emerge and it looks unobtrusive and stock.
My friend was selling these no-name tweeters for a dumbo cheap price of $10. He told me "I know these look like crap but trust me they sound AWESOME and they can perform. They have been flying off the shelf, I can't get enough!" I tried them in the B-Pillar of my old BMW and they were in fact AWESOME! In fact WAY better than the Infinitys I had in the B-Pillar of my car before that. I got these ideas in college in another country. It is commonplace to mount tweeters on the top of the windshield and B-Pillar. I don't see it much around here and it sounds stupid but trust me, that's where you will hear them better. On the dash reflecting off the windshield sounds worse.
So this is my 2nd install of these no-name speakers and they are flawless and give me much more 3D sound......
Call it 7.1 DVD Audio!! LOL
I really like that idea...couple questions:
Did you run the extra tweets parallel? And what did you wire them to?
My only concern here is that having them right next to your head would make them louder, any validity here? I don't want them to outshine the rest of my speakers.
3-d sound...exactly what I'm looking for, thats what made the rear infinity's such a great upgrade cause I can hear them up front!
all work and no play
Im going to agree with Trew, reguardless of the grade...silicone is silicone. Its great for sealing but I wouldnt count on it to keep the speakers securely attached on something that will vibrate like the rear deck.
I'd try to at least get one more screw in each speaker at the least. They made attachments that you can put on a normal drill that will make it a half assed right angle drill for getting into areas like that, worth looking into
I appreciate the concern guys but I just dont see how they would come unattached. Plus the rear deck is secured against the top of the speakers putting pressure from the top. I'll probly take out the rear deck this weekend and take a look see just to be sure. I do have plans to add an amp down the road...any suggestions?
Yes sir, the Infinities are 2 ohm just like factory. Using the supplied mounting bracket, they're one of the only bolt-ins that you don't have to cut the car or make custom brackets to install. The only thing custom is the cutting of the wiring but that's hardly custom.
Off topic, but are you still in Baghdad? My father just went back for another year.
King of NYC
Overall the treble output is HUGELY improved. Admittedly on max setting the treble can be harsh. I have it turned down quite a bit to amplify the mids and it sounds fantastic. They are not right IN my ear. They are positioned high up, right where that B-pillar panel meets the roof liner. Everyone who hears my system comments on how nice it sounds.
King of NYC
TLDude876
12-28-2016 03:18 PM
pistacio
09-26-2015 09:45 AM
