How to run power wire
Check out this thread...
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
If i'm not mistaken, you can get add a fuse and tap into #32... Correct me if I'm wrong someone...
I think you'd probably be fine running both remotes off of the same fuse. If you go with the Matrix for your line driver it should have a remote out that you can run to your amp so you'd only have one remote coming from the fuse. If your line driver doesn't have a remote out then you can just try both on the fuse and if you get a turn on pop then install a relay.
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
