How to run power wire
Old May 17, 2012 | 02:36 PM
Gizmo 04's Avatar
I've been searching and couldn't find anything, I need ton know how to run the power wire and where did u hook up the amp remote turn on wire? Thanks in advance
Old May 17, 2012 | 02:42 PM
Seatown1two's Avatar
Check out this thread...
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
If i'm not mistaken, you can get add a fuse and tap into #32... Correct me if I'm wrong someone...
Old May 17, 2012 | 02:44 PM
Trunk Monkey's Avatar
Coolest A-zine Member
^ That's the way I've done it Kenji
Old May 17, 2012 | 03:03 PM
Rather than creating a new thread, can #32 be used to power on an amp and line driver w/o the need for a relay?
Old May 17, 2012 | 03:23 PM
I don't use a relay. Unless my 3sixty.2 counts as a relay of sorts.
Old May 17, 2012 | 04:38 PM
rich20730's Avatar
I think you'd probably be fine running both remotes off of the same fuse. If you go with the Matrix for your line driver it should have a remote out that you can run to your amp so you'd only have one remote coming from the fuse. If your line driver doesn't have a remote out then you can just try both on the fuse and if you get a turn on pop then install a relay.
Feb 25, 2020 09:57 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
04tler
Sep 10, 2015 01:13 PM
Phambam12
Sep 6, 2015 06:57 PM
