Hid reverse wiring
Old Aug 28, 2009 | 04:47 AM
thait's Avatar
I need a car in
Hid reverse wiring
so im been trying to figure out wiring guage size. im going to run a set of hid reverse light and would like to know what gauge of wire i should use for my constant 12v. it will run from the front of the car to the trunk where the reverse lights are at. from what i read, hid kit takes 30amp to start up.
Old Aug 28, 2009 | 10:01 AM
ABP_04TL's Avatar
6-SPEED LOVER
get 14-16gauge
Old Aug 28, 2009 | 10:45 AM
LoveMyTL-S's Avatar
I'd go with at least 14awg. See chart in this link:
http://www.powerstream.com/Wire_Size.htm
Old Aug 28, 2009 | 11:57 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
30 amps WTF.
the usual is 6 amps start-up and 4 running.
14 is fine 16 is good. i would do 14 tho. read the ballast. it should tell you starting amps and running amps i believe.
Old Aug 28, 2009 | 12:14 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
x2 ballasts = 6x2 = 12 amps... but it all depends on the manufacturer of the HID kit. Some are more efficient than others.
I would do a 10 awg. and then do the wires to the ballasts (after the relay) in 14 awg. (Safety First)...
Old Aug 28, 2009 | 01:47 PM
thait's Avatar
I need a car in
thanks for all the reply guys
rodney has it right. the ballast does take 6 amp each and maybe a little more. would it be safe to do it in 12 gauge wire? i have a spool of those at home. also rodney i believe you have hid rear also right?
Old Aug 28, 2009 | 02:48 PM
rodneyc77's Avatar
Yes Sir... But I have 0 awg going to the relay...
Old Aug 28, 2009 | 06:58 PM
Trew's Avatar
14 should be fine.
Rodney cheated. he used his amp wire and connected his relays to it
Old Dec 9, 2009 | 08:19 PM
zsameer's Avatar
I so want to do this mod but thinking of having to run a wire from the battery all the way back is keeping me from doing it. do you have to take a lot of the interior parts off to acomplish this? Anyone in houston willing to help
Old Dec 9, 2009 | 08:47 PM
no you dont have to take alot of interior parts off. do it!
Old Dec 10, 2009 | 02:06 AM
thait's Avatar
I need a car in
nope not really but it is a pita. i did it when i was doing a upgrade for my entertainment system so it was all good
rear seat, rear side panel, trunk liner, trunk cover liner front door sill, lower kick panel ondriver side.
Old Dec 10, 2009 | 07:31 AM
zsameer's Avatar
Thanks guys. Will have to give it a go one of these days. For now i will stick with the LEDs.
Old Jun 19, 2010 | 02:29 PM
nhn23's Avatar
I live in
this is a really old thread but did any of you guys put a switch in also? how did you wire the switch?
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
