HFL Stuck on Pairing mode
Old 04-01-2008, 11:01 PM
6th Gear
t6waver's Avatar
I just tried pairing my samsung bluetooth phone to my 2004 TL. I got through most of the steps then the TL got stuck in Pairing mode.
Now all it displays on the status screen is "Pair" 0000. Now I can not use the radio/cd player/xm. It seems to be stuck in pair mode. Anyone else have this issue before? Any suggestions?
Old 04-01-2008, 11:43 PM
SlammedOnKonis
ifirahse's Avatar
Just turn the car off....then back on...
Old 04-01-2008, 11:44 PM
low budget mike lowery!
sabotfiveo's Avatar
i had mine freeze up on "phone." i pulled a "3amp" fuse from under the hood and it cleared up and hasn't happened since then. i did have to program my presets all over again. once again, i haven't had any problems since then. i hope this helps.
Old 04-03-2008, 02:21 PM
6th Gear
t6waver's Avatar
I will try pulling the 3amp fuse and post results. Thank You Sabotfiveo
Old 05-17-2008, 02:21 PM
7th Gear
kentuckyred's Avatar
t6waver...did taking the 3 amp fuse out work? i don't see it under the hood.
Old 05-18-2008, 03:52 PM
6th Gear
t6waver's Avatar
The 3amp fuse didn't work. there is a fuse box under the drivers side. In there there is a fuse for the interior lights, pull that out and put it back in. That clears it up right away. Good luck.
Old 05-19-2008, 12:55 AM
Sǝxy Timǝ in my
smsTL's Avatar
It happened to me before...you have to take to the dealership and they will replace it for you, thats if your car under warranty...
Old 05-20-2008, 07:36 PM
7th Gear
Mine is at the dealership getting replaced, hopefully that will work.
Old 05-20-2008, 11:49 PM
Sǝxy Timǝ in my
smsTL's Avatar
i told them what happened then they order the part and when the part came about week later i went back. it only took about 2hrs...
Old 05-21-2008, 06:14 PM
7th Gear
I talked to the dealership today and they told me the 2004 HFL system is no longer in stock, so I guess they are ordering a newer version that should be in tomorrow, so I'm still waiting ........
Old 06-06-2008, 08:08 PM
7th Gear
My car is still under warranty so I had my HFL replaced and it works just fine now. I love it
Old 06-07-2008, 08:52 PM
Sandy Eggo
pffpffpass's Avatar
I had this same exact problem when I recently bought my 04 TL three weeks ago. This is a known problem and is easily fixed by taking it to the dealership. Apparently if your unit was produced prior to some date then they are defective. They should know about this problem as it is pretty common on the 04 model. There is a TSB about this so you could even take a copy of this if they give you the run around. It is located
here - http://www.in.honda.com/Rjanisis/pubs/SB/B05-020.PDF
But just take it to the dealer and they will fix it for sure, (that is if your within warranty)
hashbrown
09-29-2015 12:13 PM
ivan06106
09-26-2015 04:38 PM
phillyguerrilla
09-26-2015 11:27 AM
Quick Reply: HFL Stuck on Pairing mode
