HFL Phone connecting problem
Old Apr 23, 2008 | 09:55 AM
vicdeng's Avatar
I set up my phone with my TL the other day, and when i pair my phone with the car again later, do i have to use the system option --> Pair --> 4 digits code again? Is there a command that just connect to my phone without reentering the 4 digits number since i believe my phone is named already? thanks for the info guys. I am new here.
Old Apr 23, 2008 | 10:03 AM
xen-cuts's Avatar
ROFLCOPTER!
that code pairing thing should be a one-time deal. Did your phone not store the code? That is what I would consider first.
If your car is not recalling a paired phone, then that is kind of a problem. Did you read the owners manual? (RTFM!)
Old Apr 23, 2008 | 10:16 AM
vicdeng's Avatar
the thing is i don't know what command i should call to let it recalling a pair phone? is there one?
Old Apr 23, 2008 | 11:40 AM
Will Y.'s Avatar
Registered but harmless
The phone should be detected and pair automatically without using the 4-digit code as long as you are not using the same name for 2 or more phones.
Welcome to AZ too!
Old Apr 23, 2008 | 02:11 PM
Oswald Vater's Avatar
What year is your TL? The 04's were known to have HFL problems after a while. I had this same thing happen to me. The dealer replaced the module under warranty and no more problems. I'd check it out especially if the warranty is still in effect.
Old Apr 24, 2008 | 07:45 PM
vicdeng's Avatar
mine is 05. so what command did u guys use to reconnect to a existing phone?
Old Apr 24, 2008 | 09:47 PM
Will Y.'s Avatar
None- if the bluetooth is active on any compatible phone I paired, the HFL connects automatically as soon as the ignition switch is turned to the accessory position.
Do you have a phone that is listed as compatible with the 2005 HFL in the HFL mini-site through Acura.com?
Old Apr 25, 2008 | 10:13 AM
vicdeng's Avatar
how can u tell it's compatible, and plz show me the list. I have paired my phone with the car successfully, so isn't it compatible? but just every time i wanna pair it, i have to pair it again. thanks
Old Apr 25, 2008 | 10:49 AM
xen-cuts's Avatar
ROFLCOPTER!
This is confusing everyone: after you pair it, you NEVER pair it again. You just get in the proximity of your car (like 20 feet away) and it will pair to the car if the car is on. So unless you are turning off bluetooth on your phone, you shouldn't have to do anything. And if you are turning bluetooth off and on for your phone, you shouldn't have to re-pair your phone with the car. Your car will connect to your phone automatically.
The list of compatible phones is located on a sticky for pairing phones. Sift through that.
Old Apr 25, 2008 | 11:33 AM
dmarcus48's Avatar
If you leave your BT on your phone on, the phone should connect with the car automatically. What kind of phone do you have?
Dave
Old Apr 25, 2008 | 01:29 PM
vicdeng's Avatar
is there any botton i should click in the car to connect? i have a panasonic VS6. i don't think they sell those in the US. ok. i will try it on. thanks
Old Apr 25, 2008 | 06:38 PM
Will Y.'s Avatar
See http://www.acura.com/index.aspx?init...hHandsFreeLink.
However, if your phone is not sold in the US and not listed in the site above, it either has not been tested or is not compatible with the TL's HFL system.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
visiter555
Apr 9, 2016 12:56 PM
brandnewcolony
Sep 12, 2015 10:39 AM
IndycarFaster
Sep 11, 2015 02:52 PM
