HFL being retarded
Old Oct 1, 2006 | 08:13 AM
crbnfbr's Avatar
HFL being retarded
So, I'm driving home from work last night and make a phone call with the HFL froze up. Now it's stuck saying in use and I can't even use the radio.
I was wondering if anyone has experienced a similar problem or has any ideas on how to reset the HFL? My only idea is to pull the negative battery cable for a bit and see if it resets it.
Old Oct 1, 2006 | 09:40 AM
dan.....k's Avatar
Pull the negative cable. I had something similar happen. It wouldn't stop ringing. This should fix your problem. If you have an 04, I would recommend getiing the HFL replaced. I just did this and can tell you the new one is much better.
Old Oct 1, 2006 | 09:43 AM
stever627's Avatar
there is a fuse for this that you can pull. I think it's 11 or 14...it's been awhile. it's the one that controls the dome lights...it will reset the HFL also.
Old Oct 1, 2006 | 11:58 AM
SLVR04TL6PD's Avatar
I had a similar problem....everything froze for like 5 minutes. eventually it disconnected from Handsfree from pressing the hangup button a bunch of times.
Old Oct 1, 2006 | 05:07 PM
BG74's Avatar
Maybe if you turn off your phone? That might be enough to reset the Bluetooth functionality of the HFL?
Old Oct 1, 2006 | 05:38 PM
K-Shawn's Avatar
VS#03
Yeah.....I have the same problem too, my bluetooth stays on permanently. I tried to turn it of by my phone and it has a note saying bluetooth is busy, which it wouldn't let me turn it off.
Old Oct 1, 2006 | 10:14 PM
crbnfbr's Avatar
Yeah that's what I did before leaving for work this morning I couldn't take a 20min drive with no music. One thing I found odd is the radio never asked for the code after reconnecting the cable.
Old Oct 3, 2006 | 09:24 PM
AcidHorse's Avatar
So how do you get it about getting the module replaced? My HFL is frozen now and I want to get it replaced since this is the second time it froze.
I just don;t want the dealer reconnecting the battery/or removing the fuse and saying the HFL is fixed.
Old Oct 3, 2006 | 09:32 PM
AcidHorse's Avatar
NM, just found this thread
Old Oct 3, 2006 | 09:37 PM
mrodriques's Avatar
I was just down in NC visiting family and my sister had the same issue with her '05 TL. I had to hit the hang up a few times to disconnect, then turned phone off and car off. The car on and phone on in that order, and it works OK now.
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
cali boy 91
Sep 19, 2015 01:57 PM
Markbby06
Sep 17, 2015 02:30 PM
V12 Inspire
Sep 10, 2015 04:46 PM
