Help with a DVD/navigation drive
So the old man gives me random parts every once in awhile (quality at honda r&d), and the latest score is this navigation unit. He said it works fine, but the disc is physically stuck in the unit.
I'm at a loss of how to get it out. I was wondering if anyone had experienced this before - any input is appreciated. Thanks!
set power to the proper pins and press the eject button
I did that using an old computer power supply and a volt-meter- though there's the reasonable possibility that I did it incorrectly. Worse comes to worse I can take apart my TL and hook it up to the existing wiring...
justnspace (11-30-2017)
Try to see if this thread helps
https://acurazine.com/forums/3g-tl-a...-873489/page6/
I'm not sure if the schematics on these sites are right:
HONDA Car Radio Stereo Audio Wiring Diagram Autoradio connector wire installation schematic schema esquema de conexiones stecker konektor connecteur cable shema
TheSauceBoss (11-30-2017)
