Help with a DVD/navigation drive
Old Nov 26, 2017 | 02:52 PM
TheSauceBoss's Avatar
So the old man gives me random parts every once in awhile (quality at honda r&d), and the latest score is this navigation unit. He said it works fine, but the disc is physically stuck in the unit.
I'm at a loss of how to get it out. I was wondering if anyone had experienced this before - any input is appreciated. Thanks!
Old Nov 30, 2017 | 11:30 AM
Bump mentioning this is for the 04-06 TL. I'd be happy to sell this to someone for cheap once I can get the disc out.
Old Nov 30, 2017 | 11:37 AM
set power to the proper pins and press the eject button
Old Nov 30, 2017 | 11:54 AM
I did that using an old computer power supply and a volt-meter- though there's the reasonable possibility that I did it incorrectly. Worse comes to worse I can take apart my TL and hook it up to the existing wiring...
Old Nov 30, 2017 | 11:57 AM
CD-ROM drives used to come with a little hole button thingy. you would take a paperclip to the button and out would come the CD. Not sure if it needed power to do this. or even if this DVD-ROM drive has the little pin hole
Old Nov 30, 2017 | 12:07 PM
Yeah i remember that too, i was looking for one but unfortunately I don't think these units are the same tray-style like those old ones were
Old Nov 30, 2017 | 12:18 PM
Try to see if this thread helps
https://acurazine.com/forums/3g-tl-a...-873489/page6/
I'm not sure if the schematics on these sites are right:
HONDA Car Radio Stereo Audio Wiring Diagram Autoradio connector wire installation schematic schema esquema de conexiones stecker konektor connecteur cable shema
Old Nov 30, 2017 | 12:25 PM
awesome, thank you
