Got my sound mat, but still
ok got my 07 tl dyno matted for the bass in trunk but still her rattles by liscense plate area, any ideas to stop rattle? i tried tighten and also with no plate no plate was worse need help
foam worked for me!
Put something behind the license plate, use all 4 screws. I removed the carpet, deadened the trunk lid and put the carpet back. I only get rattles when it's turned way up, way past where I normally listen to it at. In fact, from the outside you can barely hear anything from my car.
On two separate occasions I've noticed LARGER subs seem to lower vibrations. I don't have an explanation but when I went to the 15s my trunk vibrated less and when I went to the 10s in the doors, the doors rattled less at the same SPL.
06 WDP/Ebony MT NAV ASPEC
Put a piece of Dynomat on the back of the plate. Completely stopped mine. I have an issue with the inside of my tail light though. It rattles like a MOFO.
I love the setup, but something's just not quite right. Highs are harsh in some genres and bass doesn't hit as hard as I would have expected (both the 650's and the sealed sub). It's really good by most standards but I need to prioritize experimenting with x-over points and doing another RTA at some point. Just haven't had much time, and it's hot as !@#$ in Austin!
mlody
12-04-2019 02:11 PM
JDM96specCTR
10-17-2015 01:06 PM
