Going Crazy With Dva-a
Old Apr 14, 2007 | 12:27 PM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
Okay,
I have downloaded four programs already... Adobemans GUI, DVD-Audio Solo, DeepBurner Pro, and dBpoweramp music convertor and can still not get music in my TL GRR!
I have made playlists, iso's etc etc and when I pop them into the car, it just says "Disc" and ejects it. I am using DVD-Rs but DVD-AUDIO is supposed to automatcially convert them from Rs to As, but yet they still arent playing.
Any suggestions?
Old Apr 14, 2007 | 12:35 PM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
PS: I meant it to say DVD-A in the title
Old Apr 14, 2007 | 12:56 PM
Hopewilly's Avatar
Bill
I had similar problems until recently, I had a break-through.
I downloaded Adobeman's DVDA GUI from
http://home.comcast.net/~adobeman/DVDAGUI/
Add your mp3 or wav files into the software. It will convert them to WAV files and create an ISO file.
You then need to have another software program to write the DVD. I used Roxio's Creator Plus
I was able to get approximately 99 songs on one DVD. I just put them into one group, however you could add several songs into different groups.
With a 6 disc changer, I have access to 600 songs without changing a disc - That's pretty much my whole library.
Old Apr 14, 2007 | 02:24 PM
pnoi521's Avatar
Registered TL Owner
How do you get the adobeman playlist to Roxio? Will it work with Roxio Digital Media SE? I can't figure out how to burn DVD-As... Someone wanna explain it to me? On AIM perhaps? 0.o
Old Apr 14, 2007 | 02:52 PM
sunnyd787's Avatar
i am also having problems w the software. i got the mp3's in adobermans gui tool, then created an image, but then nero wont open the image to burn, dvd decryptor wont even do it...pls help!
Old Apr 15, 2007 | 06:50 PM
Hopewilly's Avatar
Bill
The Adobeman software creates a ISO file. Rather than copying each song to the DVD, you, in essence copy one large file. Adobeman put the file (on my computer) into -
C:\Program Files\Adobeman's DVDA GUI\Images
I opened up this folder in Windows explorer and then just double clicked on the ISO file (which was around 4 gigabytes) - The file opened up into Roxio's Creator Plus.
I think this is their web site - http://www.roxio.com/enu/products/re...recordnow.html
If you google "Writing ISO file to DVD" - You'll get several hits - I found a freeware program at
http://www.freewarefiles.com/program_6_205_26380.html
I've never used this program, but it looks like it'll work.
You're looking for anysoftware that will write an ISO file to a DVD.
Good Luck.
Old Apr 15, 2007 | 11:42 PM
datmrman's Avatar
Adobeman recommends DeepBurner to burn ISO to DVD.
There are already large threads on Adobeman's programs. If you go through the steps slowly and careful, you might find something you have missed.
Old Apr 15, 2007 | 11:46 PM
desper's Avatar
It was sooooooooooo easy
use the abdomen, create the iso, burn the iso using deepburner, THAT IS IT...
Took me five minutes.......
I dont see how anyone could have any problems with this
Old Apr 16, 2007 | 12:04 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
ive done the gui to iso to deep burner.... when i put the dvdr(a) in the TL it just says "DISC" and ejects the disc....
thats what im runnnning into.
Old Apr 16, 2007 | 12:07 AM
yount79's Avatar
Exclamation you guys are missing the point here...
Hi, everyone..
I need some help here...
I personally had no problem making 2 ch dvd-a's using adobeman's GUI but had no luck with 6 channel dvd-a's using DVD solo.
so far i wasted more than 50 dvd-r's and dvd+r's.
I have no problem to the point where I make .iso files using dvd solo and burn it with nero, dvd decrypter, deep burner, and etc etc etc.............. T.T
but when I put it in my TL, she never reads it!!!!!!!!
I tried 2X, 4X, 6X, 8X, 16X.
I tried dvd-r, dvd+r.
I tried nero, decrypter, deep burner, dvd solo it self for burning the image file.
I tried direct burning with dvd solo.
Please help me...please...
I'd really like to be able to enjoy my collection of songs through TL's gorgeous 5.1 ch....T.T
Old Apr 16, 2007 | 08:02 AM
Indy Paul's Avatar
I failed the first attempt I made at the 5.1 DVD, but the second time, rather than burning the DVD using DVD Solo, I had it creat an .ISO image, and then used the Sonic DVD Copy program that came on my laptop to create the DVD-A, and it worked fine. I'm using Office Depot brand DVD-R discs.
Old Apr 16, 2007 | 08:14 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
see, my issue is, I can create a playlist in Adobemans GUI just fine, and then creating the iso. I have tried NTI DVD Burner, Solo, Deep Burner and another program (cant remember, Im at work) and all have the option to burn iso's. Goes on the disc fine, but like i said, when it's in the TL, it just says "DISC" and ejects. Ive wasted litterally 20 DVD's
Old Apr 16, 2007 | 09:01 AM
Indy Paul's Avatar
I wonder if it's the brand DVD you're using? I know some folks said they could not get the DVD-R to play but the DVD+R would. I have not had a problem using DVD-R as that's all I have, and it worked fine. Have you gotten any DVD-A discs to play in your TL? I know mine came with a demonstrator DVD-A. If you haven't tried that one lately, you may want to pop it in just to verify that it's the DVD's your trying to produce and not the player.
Old Apr 16, 2007 | 09:28 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
yeah the demonstrator DVD-A disc (got it from Acura) works just fine... havent even taken it out yet...
I am using RiDATA 4.7GB 8X DVD+R that I got from newegg.com... movies, etc work just fine on them.
im sad
Old Apr 16, 2007 | 09:45 AM
yount79's Avatar
same here...
the demo cd plays fine.
and i've tried 4 different dvd-Rs and dvd+Rs. obviously wasted more than $100 buying them.
What is wrong here? I've searched through many threads and posts but couldn't find the answer yet....
Old Apr 16, 2007 | 09:57 AM
Indy Paul's Avatar
Maybe it's a compatibility problem with your burner. Not that I have anything fancy, it's the combo CD/DVD burner that came in my $599.00 HP Laptop, so I'm sure it's nothing top of the line. Like I said, using the Adobeman GUI software, I was able to produce a 2 channnel DVD-A the first time. It took two times to get the 5.1 right because I tried to burn the DVD from the DVD Solo software (trial version) and the computer locked up. The next attempt I had it create an .ISO image on the hard drive and used the Sonic software (DVD Copy Module) that came on the laptop to burn the DVD and it worked fine. I don't see why my Sonic software would work any different that the programs you guys are using, so I'm pretty much at a loss as well. Sorry I can't be of more help!
Old Apr 16, 2007 | 10:20 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
ehh idk... i work in customer service so i know to NEVER assume that IM RIGHT ALL THE TIME (like my customers think about themselves) but I built my computer from scratch... have nice parts in it.... i dont think it's the burner itself because DVD movies are just fine and I can burn regular wav and mp3 cds... idk but im not ruling that out entireley
Old Apr 16, 2007 | 10:46 AM
HiTEC's Avatar
I don't know anything about RiDATA burners.... by the name is sounds like a cheapo (could be wrong). I think you're better off going brand name with burners (Plextor, Yamaha, etc.). I always buy Plextor and I have no issues.
Old Apr 16, 2007 | 10:48 AM
lowendz's Avatar
i just got this working as well, tried 3 different burning software and found Nero works best.
all i did was made the .iso with Adobemans GUI, right click on that .iso file, selected 'open with' and chose nero.exe from program files. u have nothing else to do but press burn.
Old Apr 16, 2007 | 11:07 AM
yount79's Avatar
It's not the 2 channel dvd-a we are having trouble making it. It's the 6 ch(5.1).
I had no problem burning 2 ch dvd-a using adobeman's gui. but when I used the adobeman's script to create 5.1 ch .wav and also used dvd solo to create .iso file and burned it with nero, deep burner, dvd decrypter, and etc, my TL won't read it.
It just says " DVD-A 2 READ" with "2" flashing. After about 1 min. I have to take the disk out since it doesn't read it...
Old Apr 16, 2007 | 11:16 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
wow... i dont even know what that issue is! litterally... all i am doing... exact steps, NOTHING else:
Create playlist in group 1 (just doing 1 group for a test). Save as ISO. open ISO up with a burner (my pc automatically opens NTI DVD Burner but Ive uses Solo and Deep Burner - for examples sake I am using Deeo Burner), Deep burner Pro. I burn the ISO to my DVD disc and pop it in the TL.
"DISC" EJECT
Throw CD against the wall and take a bat to my computer... rinse and repeat.
Old Apr 16, 2007 | 11:29 AM
yount79's Avatar
"DISC" EJECT
fantom_tl, did you try dvd-rs?
For me when I used dvd+rs, my TL says "DISK FORMAT" and spits it out usually.
I've noticed it especially when i burn dvd+Rs with the Deep burner.
Tried with DVD-R----------> sony, memorex, TDK,
DVD+R----------> philips, maxwell, fujifilm
none of them worked.
Old Apr 16, 2007 | 11:43 AM
brettallica's Avatar
Godfather of Chrome
From: Santa Cruz, and yes I'm a hippie with retro 1970s sideburns and a chrome fetish
same here...
Yount, I have used both DVD-R and DVD+R; both work equally well and perform the same from what I've experienced. Something must be wrong with your procedure.
I've used TDK DVD-R and Memorex DVD+R. I've only had one "bad burn", and that happened when I bumped my laptop while I was writing the .ISO to the DVD. Other than that, smooth as silk. It takes a lot of time, but works well if you're following instructions carefully.
Old Apr 16, 2007 | 11:48 AM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
havent tried -R's. in all honesty i dont know the difference
Old Apr 16, 2007 | 11:49 AM
yount79's Avatar
thanks for your replay, Brettallica.
I don't know what to say anymore... I converted mp3 to wav with CDex, then used adobeman's script to make them 6 ch. , then used dvd solo to make .iso file.
burned it with nero, deep burner, at various burning speed(2X,4X,6X,8X,16X)
ALL FAILED to plzy in my TL...
I'm suspecting DVD solo to be the one causing it.
Is there anything else i should know about it except to leave it at default mode for pretty much everything???
I feel like crying now....
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
merc009
Sep 29, 2015 03:06 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
Medinak12
Sep 23, 2015 07:11 PM
