Garage Door Open-not working
Old Oct 26, 2007 | 09:59 PM
6spdtls's Avatar
zero to biotch:3.0s
I live in gated community and it requires gate opener to open. I programmed the gate opener to my Acura TL-S and it works as charm. But I can't program my garage door opener to the link. Can someone help me on this?
Old Oct 26, 2007 | 11:02 PM
dmarcus48's Avatar
Your garage door probably has a rolling code. You need to find the "learn" button on your door opener. On mine you press a button on the garage door signal receiver and then race back to the car to sync it up. Once you do it you're set.
I believe that homelink has a website that explains it.
Old Oct 29, 2007 | 10:54 AM
TL310's Avatar
06 TL
[QUOTE=6spdtls]I live in gated community and it requires gate opener to open. I programmed the gate opener to my Acura TL-S and it works as charm. But I can't program my garage door opener to the link. Can someone help me on this?[/QUO
I live in a gated apartment complex and have a gate. I cant get mine to work. How did you do it.
Old Oct 29, 2007 | 12:15 PM
6spdtls's Avatar
zero to biotch:3.0s
[QUOTE=TL310]
i read the instruction manual. i guess the gate opener doesn't have the rolling code.
Old Oct 29, 2007 | 12:27 PM
lusid's Avatar
FTW
did they do maintenance on the garage recently? Maybe reprogramming it again might fix it?
Old Oct 29, 2007 | 01:39 PM
6spdtls's Avatar
zero to biotch:3.0s
i think dmarkus48 makes sense to me. my friend told me the same thing.
Old Oct 29, 2007 | 03:51 PM
TL310's Avatar
06 TL
How did you do it.
Old Oct 30, 2007 | 08:56 AM
dmarcus48's Avatar
There is a button on your garage door receiver. Where it is depends on the model of opener. You press that button (a learning button, usually hidden), and while it's blinking you go back to your car and press and hold one of the homelink buttons. go to the homelink.com website for more info.
Dave
Old Oct 30, 2007 | 09:02 AM
blkaspec's Avatar
Full of water...
^^^^ i agree. my garage is the same way. there was a little red button either on top or on the back, just hit it and you got like 30-60 seconds to complete the sync.
Old Oct 30, 2007 | 10:13 AM
TL310's Avatar
06 TL
Dave
this is different for a gate. Not allowed to acess the reciever? So there for does not work.
Old Oct 31, 2007 | 08:28 AM
dmarcus48's Avatar
The gate I don't know about, obviously you use a different button. I'd ask the guard at the gate how to do it or maybe what kind of opener it's using and then look on the web for info, you can't be the only one. Look on homelink.com to see if there's a "learning" mode for the buttons.
Dave
Old Oct 31, 2007 | 03:36 PM
stevey678's Avatar
I live in a gated community too. You'll need to see if your gate security system is compatible with the homelink system.
http://www.homelink.com/brands/gate.tml
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
acurajj
Sep 19, 2015 03:47 PM
Dunnik
Sep 14, 2015 02:56 AM
ahsm
Sep 9, 2015 08:35 AM
