Fosgate 3sixty INPUT ?
Old Mar 11, 2008 | 11:12 PM
C-LOS_TL's Avatar
I JUST PURCHASED A 3SIXTY AND JUST HAD ONE ? IT HAS TWO INPUTS..AS SHOWN BELOW
I CAN JUST USE THE SPEAKER WIRE INPUT COMING OFF THE AMP RIGHT? INSTEAD OF SOLDERING RCA'S AND USING THE RCA IINPUTS?
Old Mar 12, 2008 | 06:12 AM
King of Pain's Avatar
Yes,
The RCAs are for low level inputs, like RCAs from an aftermarket HU. The wire inputs are for OEM high level inputs, like those from our stock amp.
Is that the 3sixty.1 or the 3sixty.2?
Old Mar 12, 2008 | 04:59 PM
C-LOS_TL's Avatar
Originally Posted by King of Pain
Yes,
ITS A 3sixty.1
SO BASICALLY JUST COME IN WITH THE WIRES OFF THE STOCK AMP THEN COMEOUT WITH THE RCA'S FROM THE OUT PUTINTO MY AFTERMARKET 6 CHANNEL AMP RIGHT?
Old Mar 12, 2008 | 05:01 PM
C-LOS_TL's Avatar
By The Way Thanks
Old Mar 12, 2008 | 06:19 PM
MWalsh9152's Avatar
all work and no play
Originally Posted by C-LOS_TL
ITS A 3sixty.1
correct
Old Mar 13, 2008 | 05:20 PM
C-LOS_TL's Avatar
thnaks alot !!!
Old Mar 14, 2008 | 07:52 AM
zax123's Avatar
Team Anthracite Member
There has been some debate that the INPUT to the stock amp might serve as good input to the 3sixty, but I'm not sure anyone has tried it. I have the 3sixty.1 in my car and I'm using the output from the stock amp, but I have a pretty annoying hiss coming from the speakers at all times. Don't know if taking the non-amplified signal to the stock amp would fix this?
Old Mar 14, 2008 | 09:59 AM
jptl04's Avatar
Bone stock tl-s
where are you running the wires to? i mean the speaker outputs from the stock amp to where? where is you 3sixty located at? mine was in the trunk and i ran the wires back there going from the amp. i removed the pass seat and ran them under the carpet straight to the back under the rear seat and into the trunk. i had no hiss at all doing it this way.
Old Mar 14, 2008 | 01:32 PM
Fulani has a TL's Avatar
Seem as though that "hiss" you hear is a ground loop...
__________________
Kansas City/Missouri Meet!!!
Old Mar 14, 2008 | 01:37 PM
zax123's Avatar
I ran them straight along the passenger side of the car under the carpet and mouldings and then up into that side of the trunk. I've been told to turn the gain down on my amps. I still have to try that.
Old Mar 14, 2008 | 02:40 PM
jptl04's Avatar
Bone stock tl-s
yea that might work, i took mines to a shop to tweak it and adjust the amps.
i was just thinking that maybe since thats where the main harness for the navi unit runs through that it may pick up some kind of interference and the amps would amplify that, causing a hiss. the way i ran mine there was no other wires near only speaker outputs going to the 3sixty.
i'm gonna do another install soon and will be taking that same route. only this time i'm getting the 3sixty.2
Old Mar 14, 2008 | 02:54 PM
zax123's Avatar
Back in the day, there was a way to upgrade the 3sixty.1 to a 3sixty.2. Undocumented of course. Oh well, I love the sound in my car -- besides the noise, so I'm happy with the .1
Old Mar 14, 2008 | 03:07 PM
jptl04's Avatar
Bone stock tl-s
i heard that too! fact or fiction? who knows. yea i miss my sound system! stock sounds like shit!
Old Mar 14, 2008 | 04:11 PM
Yea, I heard that too. Some sort of firmware update would to the trick.
Old Mar 16, 2008 | 05:50 PM
C-LOS_TL's Avatar
is it tru you need a pda for this?
Old Mar 16, 2008 | 06:47 PM
Uh, Yes
The palm connects to the 3sixty with bluetooth
Oh Yea, and a PC to load the 3sixty software onto the Palm
Rockford recommends one of the following.
• PalmOne Tungsten T5
• PalmOne Tungsten E2
• PalmOne Treo 650
• PalmOne Zire 72
• Sony PEG-NZ90
• Sony PEG-UX40
• Sony PEG-UX-50
• Tapwave Zodiac 1
• Tapwave Zodiac
Old Mar 16, 2008 | 07:26 PM
C-LOS_TL's Avatar
Uh, Yes
• PalmOne Treo 650
• PalmOne Zire 72
• Sony PEG-NZ90
• Sony PEG-UX40
• Sony PEG-UX-50
• Tapwave Zodiac 1
• Tapwave Zodiac
so without a pda its useless?? damnn im shit out luck guess ima sale it then
Old Mar 16, 2008 | 08:40 PM
MWalsh9152's Avatar
I think you can tune it via a laptop with a bluetooth adaptor too. Its a 360.1 right? let me know how much if you decide to sell it, I might be interested
Old Mar 16, 2008 | 09:10 PM
You may want to check the rockford fogate forums to see if there is another way to tune it without a PDA.
Old Mar 17, 2008 | 01:32 AM
C-LOS_TL's Avatar
360.1/$160
Old Mar 18, 2008 | 11:52 AM
zax123's Avatar
You can also do it with a PocketPC. They've released a Windows Mobile version of the software... it has to have bluetooth of course.
EDIT: They have a version for Windows laptops with Bluetooth also.
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
thegipper
Sep 28, 2015 01:01 PM
