FEELER: Plug and play factory amp replacement?
#282
Lukieluc (01-07-2015)
#284
King of NYC
Guys go back and read what I wrote, talked about it quite a bit. You can get your center channel working if you want to. Mine does.
If you REALLY want your sub to work there are ways around that too. I have two 12s in the trunk so I didn't care to lose the crappy sub.
True this package is not officially for sale up here......but dig around you might be able to score. And once in awhile someone might sell their PnP amp. I saw someone selling one a few months ago and surprisingly nobody bit on it right away.
Sometimes there is low demand for a great item when it is available. Then once it goes out of production it seems like there is more of a market for it. (i.e. A-Spec rims, A-Spec badges, supercomputer sills etc.)
#286
King of NYC
Of course. But the whole point of this amp is not just the dimensions. This is at least 4 channel (5 channel would have been ideal.) It outputs a LOT of power for it's size. It's efficient and doesn't require huge gauge power wires running to it. And of course the whole point here is the PnP harness.
If there is another amp that fills the bill let us know because it's been quite awhile since this amp came out. There must be alternatives by now. Something that runs 5 channels with lower impedence would be even better.
#290
and that amp is crap
#292
the rockford to fit in the OEM location
#294
keep rears on stock amp too. all power to front speakers
#295
#298
Help
So hopefully someone sees this, but i have no idea what i am doing. So if i ordered this exact same amp is it possible to plug n play with factory speakers? Trying to go the cheap route. Do i just need to get harnesses for the amp? HELP
#299
Plug and play implies plug and play
#300
#302
I still have mine. IIRC, the member (Uncald4) took some parts from the factory amp and modded a harness to plug into a small Rockford Fosgate Punch amp and interface with the factory harness to power the fronts and rears, and it mounts in the factory location. He also added a pigtail for a sub output. I've had mine for several years now, and it still does the job decently. The issue is that the L/R separation isn't great, so you lose a little of that depth. Plus the Punch amp isn't necessarily awesome, but it certainly brought some life into the audio system, and it fit into the original space. I replaced the speakers with some Imagine Hybrid Audio and added a JL 10w6 sub powered by a XD600 amp under the passenger seat.
#303
Attachment 51909
Attachment 51910
Thanks to Rockford Fosgate we've been able to deliver some amazing sound without the need for substantial upgrades to the audio system. At ICON Audio Technologies we specialize in high-end audio install. We love these new Rockford Fosgate Punch Series amps for Porsche, Lamborghini, Ferrari, Dodge Viper and new Corvette. It tucks in places that no other amplifier can. It's a great replacement or add-on to the factory amplified system.
Recently we've used it to replace the factory amp in a few 3rd Gen TL's. Most of you know how beautifully our subwoofer enclosures add amazing bass response to your TL. But there is still something missing in your front stage. It's missing power, clarity and volume. This is the cure.
Easy to install. No extras to purchase. Mounts in the factory amp location. The pictures above are from a 2004 TL. We did the install in 20 minutes from start to finish without a plug and play harness.
We are considering a group buy for the amplifier with plug and play harness. Please share your thoughts, suggestions and questions.
Attachment 51910
i know its 2019 but is this still available?
cycdaniel
12-17-2019 10:58 AM
TLDude876
12-28-2016 03:18 PM
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
