Factory Subwoofer Problem
Old Oct 3, 2010 | 10:37 AM
smayoub's Avatar
Shannon's '04 TL Nav 6MT
I just purchased an 04 TL and there is no sound coming from the subwoofer. Checked out fuses and wire connections and everything looks normal.
Purchased from a dealership so I have no idea what the last owner may have done to it.
I'm not sure what to do.... Any suggestions?
Old Oct 3, 2010 | 11:18 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Check to make sure it wasn't disconnected from the amp in the passenger kick panel. Right in front of the door (down by your feet) there is a panel shaped kinda like an "L"...kinda....and you can remove that and the amp will be underneath. If you have any exposed wires...that's probably your culprit
Old Oct 3, 2010 | 07:52 PM
smayoub's Avatar
I'll do that. I hope it's that simple!
Thank you.
Old Oct 3, 2010 | 10:42 PM
I hate cars's Avatar
I have to say this, you have the sub turned on, right?
Wiring back at the sub is connected?
Old Oct 5, 2010 | 08:11 PM
smayoub's Avatar
What do you mean by "turned on"?
Old Oct 5, 2010 | 08:18 PM
smayoub's Avatar
Factory Subwoofer Removal - Help....
Does anyone know how to remove the factory subwoofer in an 04 TL? I'm going to replace it because I have no sound (or anything) coming from it. We just can't figure out how to get it out.....
Old Oct 5, 2010 | 08:26 PM
Is it turned on at the factory controls on the Navi screen where it says "subwoofer"?
Old Oct 5, 2010 | 08:43 PM
blkaspec's Avatar
Full of water...
i think you might have to remove the rear seat.
Old Oct 5, 2010 | 09:06 PM
Originally Posted by dzionny_dzionassi
all you need to do is:
1. remove rear upper seat part
2. remove rear c-pillars
3. remove rear shelf cover
Here is link how to do that.
Old Oct 9, 2010 | 10:29 AM
smayoub's Avatar
Yes it is. I'm going to try to replace it today. Hopefully it's just blown.....
Old Oct 9, 2010 | 10:31 AM
smayoub's Avatar
Thank you for the link. I'm going to work on it today!
Old Oct 9, 2010 | 11:12 AM
Bearcat94's Avatar
AZ Community Team
Really no need for two on the saqme topic by the same OP.
Threads merged.
Old Oct 10, 2010 | 12:15 AM
SpiderX1016's Avatar
I would of done it the lazy way.
Use an Ohm Meter at the amplifier (YL/BLK and LG/RED) and/or use a 9V with jumper wires and tap them on the two wires.
Old Oct 25, 2010 | 01:41 AM
smayoub's Avatar
It ended up being the stock amp. I replaced it and now the sub works but it doesn't sound very good....
Ohwell! Thanks for all the advice!
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
scionxb3003
Oct 2, 2015 05:50 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
3GTLOwns
Sep 9, 2015 09:51 PM
