DRL warning light on
Old 01-19-2015, 04:35 PM
tonytls's Avatar
I have a 2008 acura tl type s the drl warninglight is on any suggestions??
Old 01-20-2015, 01:06 AM
jhikol's Avatar
Did one burn off? Or if you replace with LED, then the light comes on without the proper wiring.
Old 01-20-2015, 08:40 AM
Received 8,608 Likes on 6,649 Posts
Originally Posted by jhikol
Did one burn off? Or if you replace with LED, then the light comes on without the load resistors.
Fixed that for you. LED's draw less current and as such, car computers tend to think the bulb is burnt out. Adding a load resistor mimics the load of a standard filament bulb to trick the computer into thinking there is proper load.
If not LED, then one of your DRL bulbs is out. replace with another 9005 bulb
Old 01-27-2015, 10:54 PM
4th Gear
J32FurrowG23's Avatar
So if I replace stock (Canadian) DRL 9005 with anything but LED I don't need any wiring? And is there anyway on Canadian made TLs to have DRL stay on with HID?
Old 01-27-2015, 10:55 PM
4th Gear
Other than just wiring it directly to a switch.
Old 01-28-2015, 09:33 AM
I'm sure you can pull a wiring schematic and do some electrical work to get that done. Anything is possible It just begs the question, why?
Old 01-28-2015, 09:39 AM
GKinColo08TL's Avatar
Depending on year...isn't the DRL also the high beam?
Old 01-28-2015, 09:41 AM
Originally Posted by GKinColo08TL
Depending on year...isn't the DRL also the fog?
Fixed that for you High beams in our cars are bi-xenon.
sockr1
10-01-2015 01:31 AM
Rob144
09-21-2015 08:18 AM
JnC
09-11-2015 06:06 AM
Fadij
09-02-2015 08:31 PM
Quick Reply: DRL warning light on
