DRL warning light on
Old Jan 19, 2015 | 04:35 PM
tonytls's Avatar
I have a 2008 acura tl type s the drl warninglight is on any suggestions??
Old Jan 20, 2015 | 01:06 AM
jhikol's Avatar
Did one burn off? Or if you replace with LED, then the light comes on without the proper wiring.
Old Jan 20, 2015 | 08:40 AM
Originally Posted by jhikol
Did one burn off? Or if you replace with LED, then the light comes on without the load resistors.
Fixed that for you. LED's draw less current and as such, car computers tend to think the bulb is burnt out. Adding a load resistor mimics the load of a standard filament bulb to trick the computer into thinking there is proper load.
If not LED, then one of your DRL bulbs is out. replace with another 9005 bulb
Old Jan 27, 2015 | 10:54 PM
J32FurrowG23's Avatar
4th Gear
So if I replace stock (Canadian) DRL 9005 with anything but LED I don't need any wiring? And is there anyway on Canadian made TLs to have DRL stay on with HID?
Old Jan 27, 2015 | 10:55 PM
4th Gear
Other than just wiring it directly to a switch.
Old Jan 28, 2015 | 09:33 AM
I'm sure you can pull a wiring schematic and do some electrical work to get that done. Anything is possible It just begs the question, why?
Old Jan 28, 2015 | 09:39 AM
GKinColo08TL's Avatar
Depending on year...isn't the DRL also the high beam?
Old Jan 28, 2015 | 09:41 AM
Originally Posted by GKinColo08TL
Depending on year...isn't the DRL also the fog?
Fixed that for you High beams in our cars are bi-xenon.
sockr1
Oct 1, 2015 01:31 AM
Rob144
Sep 21, 2015 08:18 AM
JnC
Sep 11, 2015 06:06 AM
Fadij
Sep 2, 2015 08:31 PM
