Door speaker
Old Apr 13, 2018 | 10:37 PM
Gabe1098's Avatar
Door speaker
Hey I'm wondering what component speakers would fit in my door to replace the factory door speakers that are in now? do I need to get a certain brand and what size do I need?
Old Apr 14, 2018 | 01:12 PM
stevemk07's Avatar
The stock speakers are about 6 1/4" diameter and shallow. If you want to put in a 6.5" you will have to build a ring to install them and probably cut some of the metal on the door to fit them in. I had to cut to fit in 6" Daytons in my last car... Even more to fit the 7" Daytons in my new car.
Old Apr 23, 2018 | 05:16 PM
CountryNoob's Avatar
I myself created a custom mount that composed of the old factory plastic mount and a wooden mount that was glued and zip tied to the factory plastic mount. Although, with this configuration, I had to cut the plastic on the actual door trim since it there were more material that came out of the mounting hole. Nonetheless, I am happier with my 6.5 JL audio components than I was with the stock speakers.
*I probably would have saved money by deleting the rears and adding the money to purchasing some set of Diamond Audios, but I didn't care too much about showing off. FYI, my 750watt Sub is tuned to 400watts
Old Apr 26, 2018 | 07:46 AM
txcharvel's Avatar
If you're keeping the factory amplifier, be sure to maintain the same ohm rating on the new speakers. The factory speakers are 2 ohm. If you were to replace with 4ohm speakers, they will likely sound better but you will probably loose a lot of volume.
Also, why are you replacing the speakers? I thought my speakers were toast as they sounded very thin with no volume. After doing some research I though it might be the amplifier. I have two TLs so I pulled the amp from my other car and to test out the bad speakers. My stereo magically came back to life. Found a factory unit on Ebay for $50 and replaced the faulty amp.
If you do the speaker switch and you're happy with the results, please post what speakers you used.
737 Jock
1G RDX DIY & FAQ
Aug 18, 2024 04:37 PM
2012wagon
Apr 19, 2015 09:15 AM
anand_kmm
Apr 23, 2007 05:40 PM
badboy
Technology
Mar 6, 2006 12:29 PM
acuradan69
Oct 18, 2002 07:24 PM
