Left & Right speaker Volume different..Speaker or Head unit pbm?
Old Apr 22, 2007 | 01:09 AM
anand_kmm's Avatar
3rd Gear
I have a 2003 Acura TL, today I have observed that my left side speakers both forward and back are working nice but my right side speaker are working at low volume.
I am still under factory warranty, will it be fixed by a dealer?
What do you think the problem is ? Is it the speakers or the Head unit or amplifier?
Since both forward and backward speaker on right side arent working I am guessing its the problem with wiring or may be head unit.
Anyhelp regarding this is a great help.
Old Apr 22, 2007 | 11:28 AM
AMGala's Avatar
Lamborghini Aventador FTW
Have you checked the left/right balance on your headunit?
Old Apr 22, 2007 | 11:31 PM
AZN.M3NACE's Avatar
USDM -> JDM
just press the tune nob on the left and check every single setting, that should help you.. if it isnt then it would be the headunit because last time i had my HU being replaced for the first time, i noticed that there was no sound on the right side and they had to end up replacing it again...
Old Apr 23, 2007 | 04:23 PM
BENDER08's Avatar
Back in a TL again.
If it's not the balance then there is a problem with the head unit i had same issue in my civic few years back with a pioneer cd player the internal amplifier went bad do to one of the speakers overloading it. it was shorting out cause i forgot to tape of the the wire to the speaker and it was touching the body of the car.
Old Apr 23, 2007 | 05:35 PM
anand_kmm's Avatar
3rd Gear
I have checked using the balancing knob and checked for the volume for each speaker, just the right two speakers work at low volume compared to the left speakers. Anyways I have checked the warranty manual and it says its covered under factory warranty and I have still 500miles left on my vehicle for my warranty to expire. I have made an appointment on wednesday for the audio system check. I shall post what has gone bad.
thanks for your inputs though.
One morething I observed in my car is that there is a kind of rattling sound from the left half of the car I am not sure whether its the car sear ( since they have replaced car seat heaters once) I am getting it also checked I shall let you know guys whats the problem with that.
Does car vibrate when the engline is in idle or when you stop at a red signal? I have felt some vibrations when the engine is idle or when i stop at the signal. If anyone has same pbm let me know.
Thanks guys.
Old Apr 23, 2007 | 05:40 PM
anand_kmm's Avatar
3rd Gear
I forgot to mention I bought a extended warranty for my vehicle for $1150 @ www.bernardiwarranty.com they offer pretty good rate for acura care.
Hope this info helps for anyone who is interested in factory warranty.
I actually didnt want to buy factory warranty but I did a little research and found that 2003 acura'a have problem with transmission..So I ended up buying a extended warranty.
even if my factory warranty expires my extended warranty should cover my Audio system.
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
akbears15
15
Nov 5, 2015 07:06 AM
Frathora
Sep 28, 2015 11:29 PM
tmux
Sep 21, 2015 05:11 PM
